Question about Breville BKC700XL Stainless Steel
No hole is poked in the bottom of the k-cup. Water and grounds pour out the bottom. We have no manual.
  • 24 Answers
Hi
Copy of the manual can be found here: http://www.scribd.com/doc/21061955/Breville-BKC700XL-Manual
hope this helps.
Posted on Mar 16, 2011
Where can I find the instructions Manual?
To insure long life and satisfactory performance from your Nordic Ware Rice Cooker, follow these simple guidelines (microwave use only).
1. Before using your Rice Cooker wash it thoroughly by hand in warm soapy water or in the dishwasher (top rack only).
2.Foods with strong colors (particularly red sauces, tomatoes) may stain your cookware.Staining that may occur will not affect the use of the cookware.
(Cooking times may vary due to variations in microwave ovens.Adjust cooking times for best results in your oven.)
To Cook Rice:
1. Remove basket.
2. Pour 1 cup of uncooked rice into the bottom of the basket, rinse rice thoroughly with cold water.
3. Transfer the rinsed rice from the basket to the bottom of the cooker.
4. Add 1 1/2 cups of water and 1 tsp salt (salt is optional).
5. Secure lid and lock clamps. Open vent holes.
6. Microwave on medium setting (50%) for 10 - 12 minutes (white rice) or 18-20 (brown rice).
7. Remove from microwave, close vent holes and let stand with the lid fastened for 4-5 minutes (the steam continues to cook the rice.)
8. Remove rice from the cooker and fluff with a fork.
Yields: 3 cups of cooked rice or 4 to 6 servings.
Cooking Potatoes and Vegetables:
1. Insert Basket.
2.Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
3. Peel vegetables (if desired), cut into evenly sized pieces and place inside basket.
4. Secure lid and lock clamps. Close vent holes.
5. Microwave on high for 3-4 minutes.
6. Remove from microwave and let stand with lid fastened for 3-4 minutes (the steam continues to cook the vegetables.)
Cooking Pasta:
1. Remove basket and lid (lid not used initially for preparing pasta inside the microwave).
2. Pour 2 cups (5 oz.) of uncooked noodles into the bottom of the cooker.
3. Add 2 1/2 cups water.
4. Microwave on high setting 10 minutes, stirring after 5 minutes.
5. Remove from microwave, stir noodles, secure lid and lock clamps. Close vent holes. Let stand for 3-4 minutes.
HELPFUL HINTS TO ENHANCE THE FLAVOR OF ANY MICROWAVE DISH:
1. Use chicken broth instead of water for added flavor.
2. Add a little butter or oil to contents.
Jul 30, 2014 | Nordic Ware Kitchen Appliances - Others
It wont brew
Carefully clean the sharp pin that pouches the hole in the top of the k-cups by inserting a toothpick or paperclip into the hole where the water is pushed into the k-cup.You need to descale it by cycling some vinegar and water through it. Pour a couple cups of vinegar and a cup of water in the reservoir push the large cup size, you can reuse the vinegar mix just don't pour any grounds back into the resevoir.Do this several times (you should see noticeable improvement)then run some clean tap water through so your coffee doesn't taste like vinegar. Hope this helps!Justin
Mar 29, 2014 | Keurig Coffee Makers & Espresso Machines
Csx22br freezer ice build up water runs out bottom of freezer
Your defrost drain hole may be plugged or frozen over. Open the freezer door and remove the lower shelf and basket so you can get to the back evaporator cover, and right under it is the drain hole. Remove what ice may be built up and pour very hot water into drain. It helps to have a syringe to remove the water and pour more hot water into drain. Then use a wire or other flexible tubing to poke into drain to clear restriction then flush with water.
Oct 30, 2011 | Hotpoint Refrigerators
We have an older style white Bunn Pour-omatic coffee maker. Model GR. Model # D-267.325. We are looking for the nozzle that screws onto the bottom of the water tank and disperses the water into the...
you should be able to go online and locate a bunn service centre in your area, contact them and purchase a 5 hole sprayhead. It will be metal instead of plastic but will work fine.
Sep 05, 2011 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
On two different occasions now, we've had a problem with grounds in our cup. Happened several weeks ago and I decided I just had a bad batch of kcups, Haven't encountered the problem again until...
There's a needle that punches a hole on the bottom of the K-cup. That needle is clogged. Poke it with a paper clip or a thinner wire to unclog it.
Aug 23, 2011 | Keurig Elite B40 Coffee Maker
When my machine makes a cup of coffee it continues to drip water after the brew process - when you remove the K-Cup it dumps about an ounce of water.
Aug 23, 2011 | Keurig Special Edition B60 Coffee Maker
The coffee grounds are dry after the cup is brewed. It does not taste like fresh brewed coffee.
There's a needle that punches a hole on the bottom of the K-cup. That needle is clogged. Poke it with a paper clip or a thin wire to unclog it.
Aug 23, 2011 | Keurig 5048 My K-Cup Reuseable Coffee...
My mansfield toilet 160 has a weak flushing problem
My toilet had same problem:
I thought it was a clog in the drain pipe.
But the problem was clogged holes where water flushes into toilet bowl.
Here's how I fixed problem.
Purchase:
Gallon of CLR calcium-lime-rust remover from Home depot.
Pumice stone from hardware store.
Home supplies:
Cut off bottom of empty clorox bottle to make container for CLR
Old 3" paint brush you don't use for anything else to apply CLR
Small cup to pour CLR into toilet flapper opening
Steps:
Look inside toilet bowl under rim and see holes where water comes out
Use brush and apply CLR to holes where water comes out.
Use pumice stone to scrape ... pumice stone will not hurt toilet surface.
Flush toilet to clear holes so far.
Turn off water to toilet.
Open flapper to drain tank.
Keep flapper open.
Use cup and pour dose of CLR directly into flapper opening.
(You can also pour CLR down overflow tube... but flapper opening puts whole dose directly onto problem)
Pour another cup of CLR into opening.
Notice how CLR starts coming out the holes into bowl.
Pour CLR down flapper hole until it runs easy and fast out of holes.
Close flapper, turn on water, toilet fixed.
Nov 22, 2010 | Home
Manual
Here are the instructions that came with the cooker:
Cooking times may vary due to variations in microwave ovens. Adjust cooking times for best results in your oven.
To Cook Rice:
1. Remove basket.
1. Insert Basket.
2. Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
Cooking Pasta:
Sep 01, 2008 | Nordic Ware 64000 8-Cup Rice Cooker
Revere Ware old fashioned coffee pot
1) Boil the water you’ll need in another pot.
2) Put 1 tablespoon of ground coffee (drip grind, not percolator grind) in the reduced diameter, perforated bottom of the brewing chamber.
3) Put the grind/water separator (the perforated, flat handled plate with cup markings on the handle) in the Brewing Chamber, over the coffee grounds.
3) Put the Brewing Chamber on top of the Holding Chamber.
4) Pour the appropriate number of cups boiling water into the brewing chamber; put the lid with the black knob on the brewing chamber.
5) Let the water drain through the coffee grinds (5-10 minutes).
6) Remove Brewing Chamber, clean out the coffee grounds, and replace the lid on the holding chamber.
7) Enjoy your coffee! Keep it warm on the stove at LOW heat setting.
for the most information on the Revere cookware lines, go to: http://mysite.verizon.net/vzeoywo4/theshineshop2/id1.html
Charlie
Jun 16, 2008 | Coffee Makers & Espresso Machines
Breville BKC700XL Stainless Steel Logo
244 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
