Question about Kenmore Elite HE3 Steam 8674 Dryer
The dryer has power and works, but there is no heat?
    Genius:
  • 1,114 Answers
If the heating element shorts to ground the unit will overheat while running until the thermal fuse trips cutting off power to the motor. I recommend replacing the heating element, and the thermal fuse. Be sure to check for a blocked exhaust vent before starting the dryer to prevent another failure. If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a appliance repair technician.
Posted on Mar 16, 2011
Whirlpool Dryer LEB6200KQ0 - Issue will not heat. Have checked Power, Getting 220 volts (110 on each line at dryer) Checked Heating Element. Have continuity. Checked Thermal Link. Have...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 06, 2011 | Dryers
Tip
Electric dryer will not heat?
If the electric dryer does not heat at all then there are some possibilities that have to be checked to confirm the fault.
1)check whether you are getting power to the dryer from electric out let to which the dryer is connected. The power problem can also occur if the fuse is blown or the circuit breaker is got tripped.
2) Other possibility for dryer not heating is the blown thermal fuse. The thermal fuse is located to the exhaust duct inside the back cover panel. This fuse blows out if the dryer gets overheated or any short circuit occurs in the house when dryer is in working.
3) The other possibility if the power is ok and if the thermal fuse is ok. Then the problem can be due to fault in the heating element. The heating element looks like a long coil of special wire. You can check heating elements continuity with an ohm meter. If there is no continuity that means the element is bad and you need to replace it. The heating elements cannot be repaired it should be replaced if faulty.
4) But if all the above mentioned possibilities checks out OK, and still the same problem, then there is a fault in the wiring. Check the main power cord of the dryer which you connect in the electric out let. If the power wire is got internally burned out or got cut in between the dryer will not get proper power and will not work Due to partial power.
This will help. Thanks.
on Mar 23, 2010 | Dryers
The dryer does not heat. All electrical circuits have been tested and there is power to the dryer on both legs of the power cord. The cool down light stays on with the sensor dry and timed dry settings and...
heatman101
May 21, 2011 | LG DLE2050 Dryer
My dryer works fine for about 7 mins then it stop and says f03
this is what it means :
    F03
  1. This code indicates a problem with the dryer's heating system. The code will appear when the heating circuits are broken or when there is an intermittent break in the power source for the dryer. If the heating circuits are working and the power source is steady, you may need to replace the central control board.
Feb 15, 2011 | Frigidaire FEQB4000F Dryer
We moved into our new home, we connected the washer and dryer, the dryer was working fine, our dryer is a whirlpool dryer and it electric, it a duet, the model number is GEW9260PW0 the dryer was working...
sounds like the element could have went out. if you cant take the dryer apart you should call a service co. always disconect the power before working on it.
Dec 23, 2010 | Whirlpool Dryers
No heat. Elec. power OK. 12 years old
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 19, 2010 | Whirlpool WGD5200TQ Gas Dryer
Dryer willnot heat
heating eliment is most likely burned out. Better off getting new dryer. But if that is not an option then call a repair person that can replace the heating element.
Nov 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer wont heat
Hi.
Check thermostat Make sure you are getting power to the element and stat.
If not , then timer probably faulty
Nov 22, 2008 | Kenmore 62602 Electric Dryer
Kenmore gas/electric dryer
theordis:
When you say electrical power is working Ok ,I would assume you are saying this because the dryer is tumbling.
Which could mean you are only getting 120 volts to the unit but it will not heat with out 240 volts.
If you are getting 240 volts.
You could have an open thermostat, an open heating element. A bad timer contact or a open switch on the motor.
All these can be tested with a Volt-Ohm meter.
((((The Electrical supply must be turned off and at least one wire dissonnected from the component being tested.
woodychoppers
Aug 13, 2008 | Kenmore 75944 Gas Dryer
This is the 2nd time my dryer in 1 year just stopped working and last time it cost me $100
http://www.repairclinic.com/0088_8_1.asp#Level1_1
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
There's no heat If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | Frigidaire Dryers
Kenmore Elite HE3 Steam 8674 Dryer Logo
66 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
