Question about Fanstel ST118B Corded Phone
How do I program the message button? - Fanstel ST118B Corded Phone
    New Friend:
Press Save and follow the prompts. Select the "Messages" button when prompted "Save To?".
Posted on Aug 19, 2013
Delete recieved messages
The top bar of what application program? What program is missing the delete message button? Is it your email? If so, what is your email client (yahoo, gmail, etc.)
May 23, 2012 | Computers & Internet
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    How do I set my speed dial numbers?
    Which ones? System speed is programmed from station 10 or 11 and goes in the 6xx's, depending on your version of software. The start is FEATURE 00 FEAT 6xx and dial the number You can continue programming more numbers by pressing FEAT 6xx or Feat 00 to exit.
    Personal speed dial numbers are programmed similarly, except they are in locations 80-99 on each phone and can be programmed from the phone if it's a system phone.
    Auto Dial buttons use blank buttons on your set. Feature 00 pressing the button and dialing the outside number store those. Again, Feature another button will let you program another button, or Feature 00 ends programming.
    Carl
    Jul 12, 2011 | Lucent PARTNER18 Corded Phone
    I have the message CO Not assigned ,How can assig CO? panasonic kx-t7730
    Press program button, select button you want to program, dial 0 then dial CO number as in 001 according to which CO line you wish to program. If you are not sure which CO line is missing, check the button programming by the same method. Press program button then any programmable button and it will be identified in the LCD screen. The CO lines may be 2 digit if you have an older system as in 01, 02, etc
    Jan 26, 2011 | Panasonic KX-T7730 Corded Phone
    How do i program my channels
    Hello
    Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
    Programming channels automatically
    Your TV can automatically detect all active channels and store them in
    its memory. After the TV has stored the channels in its memory automatically,
    you can add or erase channels manually.
    To add channels automatically:
    1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
    2. Press "Up arrow"or "down arrow" until the TV/CABLE
    selection is highlighted.
    3. Press "left arrow" or "right arrow" button to highlight either
    TV or CABLE, depending on which you use.
    If you use an antenna, choose TV.
    If you use cable, choose CABLE.
    4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
    5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
    cycle through all the TV or Cable channels (depending on which you
    selected), and store all active channels in the channel memory.
    While the TV is cycling through the channels, the message
    "PROGRAMMING NOW-PLEASE WAIT" appears.
    6. When channel programming is complete, the message "COMPLETED"
    appears.
    7. Press CH UP or DOWN button to view the programmed channels.
    OK.
    Dec 14, 2010 | Toshiba 26HF85 26" TV
    Please we have a problem with de telephone. can
    the button on your phone has been reprogrammed. it is easy to program the button back, but you will have to get the extension for the voicemail. the easy way is to go to another phone, go into program mode on another phone go to key programming and press the button used for voicemail access and see where it points to. then go to your phone and do the same, go into program mode press the button you want to program and enter the extension that goes to voice mail. Program mode on the individual phone is access through a Program button or a softkey under the screen. I was just on the Panasonic dealers website to see if I could find you a Pamphlet to email you that explained this, but there is no information available for your phone, too old.
    Apr 09, 2010 | Panasonic KX-T7431 Corded Phone
    1. Create a message box in Win32 programming, on
    yaddu khud kar le bhai aasan hai
    mridul
    Mar 11, 2009 | Computers & Internet
    Cannot recieve text messages and read messages keeps deleting
    i just went through this problem today... go to options and the scroll down to status.. if it says 0 bytes then you need to clear all old texts, after you do that make sure all programs are closed. You do this by holding down the ALT button and the return button.. make sure you close every last one of the programs.. take your battery out, then you should be go to go!
    Mar 10, 2009 | AT&T Blackberry Curve 8300 Smartphone
    Message displays: Windows has closed this program. But not closed
    have you recently installed or uninstalled any programs recently? around the time this has started?
    it could be an interfering program, or may likely be a virus problem.
    let me know and we'll get started fixing this :)
    Dec 25, 2008 | Microsoft Windows Vista Ultimate Edition
    21095GE2-a user manual
    I have the manual and can scan or fax pages if you want. Contact me if you still need this at: twoeyes4you@yahoo.com
    My system just quit allowing me to listen to messages and all three batteries quit. I'll probably have to get a new phone system.
    Let me know if you need handsets and cradles too, I have 3!
    Judy
    Aug 26, 2008 | GE 21095GE2 Cordless Phone
    Fanstel ST118B Corded Phone Logo
    60 people viewed this question
    Top Fanstel Lands Phones Experts
    David Burbee
    David Burbee
    Are you a Fanstel Lands Phone Expert? Answer questions, earn points and help others
