Question about Car Audio & Video
My radio is on error code 2 - Car Audio & Video
  • 4,886 Answers
Try leaving it SWITCHED ON...UNDISTURBED for as long as it takes for it to automatically reset itself ( An hour or longer)
Make sure you have the correct code
Posted on Mar 16, 2011
Testimonial: "Thank you!! I left it on for one hour and it has reset by itself"
How do i get i n h off of display of my radio shack htx 202
HTX-202 (190-1120) Error Codes Faxback Doc. # 15722 Your transceiver has two error code displays. Refer to the following for an explanation of each error code. Er1: INTERNAL RAM ERROR Er1 indicates the transceiver has detected an error in its battery-backed up operation memory. This is the most commonly caused by a low lithium backup battery, but can also be caused by static discharge, or a physical shock. To clear the error-- 1. Turn off the unit. 2. Press FUNCTION and CLR (the D key). 3. While holding these keys, turn unit on. This will reset unit and clear memories. If the transceiver frequently displays the error, have the battery replaced by an authorized Radio Shack service center. ER2:PLL UNLOCK ERROR Er2 indicates the transceiver's PPL section has unlocked. Have the transceiver repaired by an authorized Radio Shack service center. (/ir-07/31/95)
Nov 01, 2014 | Radio Communications
Put wrong code in radio now cant clear the error display
try hold number 2 & 5 while radio off while holding switch radio on this should go to factory settings
Aug 31, 2014 | 2003 Renault Megane
My battery died for my 2007 honda civic and now the radio will not turn now.. it says error code.. how do i fix that ?
----- Error code radio Honda Civic 2007 -----
power on radio, when you see Error code 1 or 2 or 3 ..., power off the radio, press the keys 6 and 1 at the same time, and power on, you'll see the radio serial number, write down this S/N and call your dealer, give him this S/N, he will give you the code (5 numbers), that's it that's all
Lahoucine Dahir
Feb 27, 2011 | 2007 Honda Civic GX NGV Sedan
I changed the battery in my 2007 Honda Accord LX. Now the radio clock is flashing and when I try and turn on the radio is says ERROR #. Each time I touch any buttons it spells out CODE one letter at a time...
Look in the glove box for the code , some dealers stick it to the box door. When it ask for code punch in those numbers. Some dealers put the code in the front of owners manual too. I think its five numbers
Dec 30, 2010 | 2007 Honda Accord Sedan
Battery ran down.now radio/clock don't work. flashes Error.can this be reset?
try taking the radio out and looking on the top for the parts number. call Honda and tell them what is going on and they will give you a 4 digit code that will reset the radio. i had the same problem with my 05 civic, did that and it worked for me.
good luck
May 29, 2009 | 2007 Honda Accord Sedan
Peugeot 206 radio Error 2, what does this mean?
i don't know what error 2 is. It might mean that you tried too many attempts to enter the code, causing the radio to 'lock up'. When this happens, some radios 'auto clear' the error code after a fixed period of time (anywhere from 3 hours to a couple of days). Others can't be cleared without sending the radio back to the manufacture (but try simply disconnecting the battery, and reconnecting it, first)
Assuming that you can get back to the position where you can enter the code, here's how to do it. I'll use the code 4968 for my example:
Press button 1, 4 times
Press button 2, 9 times
Press button 3, 6 times
Press button 4, 8 times
Press button 6.
try leaving your ignition on for an hour or so and see if the error 2 message changes to the option where you have to input a code.
check you peugeot manuals to see if the previous owner has noted the code down if not hopefully you should have a stereo manual whihc will have the serial number on it .if not then you will have to remove the stereo and get the serial number off the back.
if you take the serial and logbook to a peugeot dealers they will beable to give you a code usually free.
let us know how you get on and please rate
May 06, 2009 | 2005 Peugeot 405
Acura tl 2008 CODE ERRORE
radio is locked out from installing incorrect code to many times need to disconnect battery for couple minutes then reconnect and install correct code
May 02, 2009 | 2001 Acura MDX
How do i get code for radio on my honda oddysy
Fix Error Code 39 - 2 Minute Error Code 39 Fix. Free Download. 100% Guaranteed.
Free.PC-Error-Repair.org
Nov 14, 2008 | 2007 Honda Odyssey
Honda CRV Radio Code Error
My car (2005 Honda CRV) was shipped overseas and the radio asked for a code. After several tries, I searched the internet for a solution. Apparently Honda now allows you to obtain the code through their provided website. You will need the VIN #, the phone number and zip code that is on file when you purchased the car. Our car was purchased used and did not come with a manual. When I went to enter the code in I had already entered too many tries, now it reads ERROR E.
However, even before having the code (as well as now that it reads ERROR E) I can get the radio working. Push in preset buttons 1 and 6 and push in the power button simultaneously. A long number appears - at that point I pushed preset button 2 and the radio operated normally. Unfortunately, I do need to do this each time I turn the radio on.
Apr 26, 2008 | Car Audio & Video
Car Audio & Video Logo
90 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
