Question about HP DeskJet F380 All-In-One Printer
I have window 7 and hp380 all in 1 old driver doeas not install
  • 89 Answers
Posted on Mar 16, 2011
How do i get latest driver for Sapphire Radeon HD4670 to install in windows 7?
First uninstall the old drivers and the CCC.If you don't you can have problems.
May 24, 2014 | Asrock 4CoreDual-SATA2 R2.0 Motherboard
Tip
Upgrading Toshiba Satellite A105 to Windows 7
Before you do anything I strongly recommend you upgrade the RAM to 2GB. Your system can only support 2 GB of DDR2 PC2-5300 with a maximum of 1 GB per slot. Windows 7 will work OK with 1 GB, but more is better! One memory stick can be found under the keyboard, which can be accessed by popping the top plastic strip right in front of the monitor, unscrewing the two retaining screws, and lifting the protective film over the memory. The second module is on the bottom of the system . You unscrew the memory compartment, which is located directly below the battery and to the right of the Toshiba model sticker.
The rest of this Review is pretty much for any system. I will be providing more How-Tos specific to certain laptops soon.
Next, I suggest you clean install Windows 7 on your system. Even when clean installing, Windows 7 can preserve your entire original installation in a Windows. old file in the root of C:. This means you will be able to retrieve all of your documents and everything else, even run old programs from this folder temporarily. However, I would suggest migrating your files from windows.old to their corresponding folder in Windows 7.
Windows 7 has a massive preloaded driver database, so most of your hardware should be installed immediately. If there are drivers missing, and even if everything is covered, you should run Windows Update immediately to ensure you have the most current version of Windows 7 and all hardware drivers.
Finally, you need to the "Toshiba Software Installer for Windows 7" . This will install the "Hot key functions" and additional drivers for the notebook that is not detected by Windows 7.
Go to the link below:
Enjoy Windows 7!
on Jan 29, 2010 | Toshiba Satellite A105 Notebook
Windows 7 audio driver
MSI have create no driver for K9MM-V under Windows 7, but usually Windows 7 & Vista automatically recognize old audio chipset, strange that your installation has not installed the driver. Have you tried with Windows XP driver? sometimes it did the trick.
Oct 27, 2013 | MSI K9MM-V Motherboard
I just bought a new computer, is comes with windows 7, it will not install my printer software, what should I do?
It is most likely due to the original software not being compatible with Windows 7. Go to the printer's manufacturer's website and look for "download drivers" or something similar. Download the drivers for Windows 7 (make sure you select 32 or 64 bit according to your computer) and install these drivers. If the printer is very old (4-5 or more years old), there may not be drivers available.
Dec 14, 2010 | Office Equipment & Supplies
I ned driver for windows 7 becawse i cant install my old driver
Incompatible types and version of printer drivers when installed in Windows 7 can cause issues which might hinder the installation process thereby causing the installed drivers to become corrupt. The users of Windows 7 are therefore advised to verify the version and type of printer drivers before the installation and install only those drivers that are fully compatible with the Windows OS on the system to avoid these kinds of issues.
Nov 19, 2010 | Toshiba e-STUDIO 4511 Printer
Have a GSC-R30 Toshiba camcorder, have had it for a few years. never used it to download my movies, although I installed the software on my old Windows XP computer. NOW, I just bought a new computer with...
I question your use of the word 'new' to describe a Win 7 computer, and with a camcorder that old, it will be impossible to find drivers for any OS later than XP.
Jun 03, 2017 | Toshiba GSC-R30 Camcorder
Driver compatible for windows 7..
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Jan 26, 2010 | DFI NF4 INFINITY Motherboard
I have a Canon MP620 Wireless all in one printer - it is printing and copying fine, but whenever I try to scan, it aborts due to scanner driver. It was working perfectly until I installed Windows 7...
If you upgraded from Windows Vista to Windows 7 on the same computer, did you uninstall the MP620 drivers first? If not, the old driver files can be causing the problem.
To correct, go to this link, type "windows 7" in the search box in the center of the screen, and click on the Search button. Now click on the link "ERROR: Cannot communicate with printer after upgrading to Windows 7". You will have a step-by-step procedure for uninstalling the old files and downloading/installing the Windows 7 drivers (printer and scanner).
Dec 29, 2009 | Canon MP610 Photo All-In-One Printer
Running digi 001 on windows 7
i got digi 001 running on windows 7...
i left my xp on hard disk while installing win 7. it kept xp on folder windows.old folder. in control panel i saw digi as multimedia adapter wich system couldn't recognice. hit "change settings" -> driver -> update driver
used my old windows to search for driver. it found "Dalvin.sys" driver for adapter. installed that. after that windows recogniced digi 001.
downloaded "digidesign asio 6.11" driver installer for win-xp and ran it.
and bingo - it works!
in every step windows was complaining and asking do i want to do this. just yeah'd everything. as i just had a clean install of win 7 i just thought whatta heck i can install everything again if it would not work, but it did.
so in a nut shell:
1: install Dalvin.sys in control panel for digi 001
2: run digidesign asio 6.11 driver installer for win-xp
for me it worked but i absolutely take no responsibility if you mess your system with this! at least reaper got a sound out of it. i haven't tried to record anything yet. but asio settings seemed to work as they used to do in xp.
- veikko-antero
Mar 17, 2009 | Digidesign Mbox 2 Barebone
HP DeskJet F380 All-In-One Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
