Question about Brother MFC-5440CN All-In-One InkJet Printer
I have mfc 290 c all in one problem t gives error no 46 what i cando tell me please
  • 3 Answers
This is caused by the performed purge sequences reaching its limit. To reset the counter, press menu then press *2864 within 2 seconds ("maint" should be on the display and all the lights should be flashing, if not try again), then press 80, then keep pressing black/mono start button until screen displays "purge count", press 2783 to reset purge count, then press stop/exit key, then press 99.
Posted on Mar 16, 2011
Brother MFC-465CN printer. Need a fix for error 46.
The problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Jul 09, 2010 | Brother MFC-465CN InkJet Printer
Troubleshot 46 on mfc-240c
Error code 46 means that your ink absorber pad needs to be replaced. According to Brother, only an engineer can do that, but you can get more information from them by contacting Brother support:
http://www.brother-usa.com/Support/
Click on "Send us an Email" and tell them your printer's model number, the error code, and whether or not your machine is covered by a warranty.
Jun 09, 2010 | Brother MFC 240C All-In-One InkJet Printer
Trouble shooting and routine maintenance
46 means the ink absorber box is full, it only costs around $10.00 to replace but you need to get into service mode to reset the counter. I'm not allowed to give out that info...
Sep 15, 2009 | Brother Multi-Function Center MFC-240C...
Cleanin printer brother
The 46 message tells you that the used ink collector is full. The only fix is to take it to a shop to replace the flushing box and reset the count to clear the error code.
Jun 25, 2009 | Brother MultiFunction Center MFC-440CN...
Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
Jun 11, 2009 | Brother MFC-465CN InkJet Printer
Error 46 in brother mfc-440cn
Machine Error 46 ("Unable to Clean") indicates that the wasteink is full. Basicly it gives you two options - have it replaced (a semi-complicated performance which requires buying a spare part and change it yourself) or have it sent to service. If you do not have any warranty on the machine, the more suitable would probably be to just replace the machine instead, since it's relatively cheap compared to both service costs and having the wasteink replaced, but you instead get a full new warranty on your new machine.
Unfortunately, there's nothing you yourself can do to remove this error, without actually changing an item inside the machine.
Jun 04, 2009 | Brother MultiFunction Center MFC-440CN...
Already purged mfc-210c but the same error
não entendo ingles não poderia mada mensagem em portugues
Jan 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Error 46 on a Brother MFc-8840DN
According to the Brother MFC 8840DN manual:
Machine error code xx: MFC has a mechanical problem
Solution: Call Brother customer service and tell them the error number
USA 800-284-4329
Remember to rate users who offer their expertise to you at no cost :)
Sep 29, 2008 | Brother Office Equipment & Supplies
Brother MFC-5440CN All-In-One InkJet Printer Logo
128 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
