Question about Indesit W 123 Front Load Washer
WIL143S 1400 Will not drain water. - Indesit W 123 Front Load Washer
  • 4,924 Answers
If the draining step is not completing and the washing process is stopping ..check the evacuation pump cause something is blocking the spining .....
it has an access point either in front after removing the lower horizontal lid ...or in the back ...its a screwing lid about an inch and a half in diameter .....and you can get inside and remove whatever ist blocking it ....
if this isnt the cause you have to change the evacuation pump..
Posted on Mar 16, 2011
My model is zanussi easy iron washing machine capacity 6 kg spin 1400 ,my problem is that clothes are not getting dried, water remains in the clothes, what is the problem .
Your washing machine has a problem with the water unless it is washer-dryer. Water remains in the appliance because drain pump is not functioning properly and laundry is wet.
Dado
Mar 16, 2015 | Zanussi Washing Machines
Manual zanussi essential 1400
You have a bad Drain Pump! It needs replacing. Unplug the machine first, Drain all the water out.
Jan 19, 2014 | Washing Machines
Hi, i have a bosch classixx5 washing machine(1400) , it's going through it's cycles until it tries to drain & then nothing, it won't drain... Please could you offer suggestions & s
You first of all need to check the pump filter. This is located at the bottom front right of washer. Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean. Of course be prepared for a lot of water and junk. The pump itself is directly behind the filter housing, check there to see if anything is stuck in the plastic blades. It should turn freely. Your washer door will not open if there is water in the washer, just some kind of precaution, so don't force the door.
Pl click if helped..
Mar 17, 2013 | Bosch Washing Machines
My bosch classixx 1400 express washing machine has become very noisy when draining water, it never used to be. Any ideas?
If it is only noisy when draining the water, then could be something stuck in pump.
There should be a filter located at the bottom front right of washer behind a cover.
Unscrew anti-clockwise to remove and clean, and look inside the pump opening as well to see if anything is stuck there.
Apr 13, 2010 | Bosch Classixx WFL 2462 Front Load Washer
Indesit wil143s washing machine.hot water not
More than likely, the solenoid valve is either gunked up or no longer has power. It is very common for hard water to corrode it and cause it to stop operating. You can try to disassemble and clean it, but replacement is often to best long-term solution.
Hope this helps! Rate my solution!
Jan 05, 2010 | Washing Machines
F04 error message on a bosch exxcel 1400 washing machine, then the water wont drain away
This error indicates an obstruction in the water pump. . Tip machine back so you can fit a bowl under the bottom right hand side. Flip back cover at bottom right to reveal pump filter access - unscrew (quite a bit of water comes out so have the bowl ready).
Sep 26, 2009 | Washing Machines
Problem with a indest wil143s
it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 06, 2009 | Washing Machines
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Indesit WIL143S flashing lights
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Indesit W 123 Front Load Washer Logo
154 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
