Question about Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder
When turned on unit emits clicking noise (4 lots of 3 clicks), then displays message HDDERR. disc tray then opens and stays open. unit turns off with tray still open.
  • 77 Answers
Your tray circuit is damage thats way this error is coming plz repair ur tray circuit or cleane it and then us it
Posted on Mar 16, 2011
How to update firmware for vizio vbr100
To update the firmware for the Vizio VBR100 Blu-ray player, you need to download the firmware package to a computer with a CD-R or other optical disc burner. The firmware is a .zip file. Next extract the contents of the compressed folder to see the .ISO file. Use the computer program to burn the ISO to CD. Windows 7 and later included this type of program (right click on the file and choose Burn disc image). For other systems, you need a program that can burn image files to disc. Nero Burning ROM is one such program.
Now make sure that the player does not have an optical disc in the unit and turn it off. If possible, plug the Blu-ray player into an UPS (battery backup). Turn the player back on and wait for the No Disc message. Press Eject to open the disc tray and put in the CD with the firmware. Close the disc tray. The Loading Disc message should appear on the screen followed by the firmware screen. Press Select on the remote to start the update process. (Use the down arrow followed by Select to cancel the procedure.) Wait for the update to finish; you do not want the power to go off during this time. The disc tray will open when the "Success" message is displayed. Remove the CD and press Select. The unit will restart. To check your firmware version, turn on the Blu-ray player with no optical disc in the tray. When you see the "No Disc" message, press eject to open the disc tray. Press the digits 7 8 0 4 in order on the remote. Look at the Revision number of the firmware.
Note: not all versions of the VBR100 can have the firmware updated. Also, Vizio no longer supports this model. There are some third-party sites that claim to have the file. Use caution; suspicious code can be added to the file by various parties.
I hope this helps.
Aug 04, 2016 | Vizio Televison & Video
Dvd door will not open
with the unit turned off press and hold "8", and then press "x" on the unit until "unlocked" appears on the screen.
This is from page 83 of the manual regarding tray lock feature.
Nov 18, 2007 | Televison & Video
Canon pixma mx892 front door flap broke - was printing but now I get lots of clicking noises and then a message telling me to power off. The rear paper tray does work but lots of clicking.
What's the error message? Did it give you an error number?
My first thought: That printer detects if the front door is fully open, and if it's not, it gives you an error message and makes you turn it off and on. So look at the hinges where the door was connected and see if you can see the switch that tells the printer whether the door is open. Then figure out how to move that switch to the "open" position.
I hate that front door.
May 03, 2015 | Canon Office Equipment & Supplies
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
How do I enable this player to become multi-region? I believe it's based on a Pioneer rather than one of Teac's own designs.
Hi
Thanks for using FixYa. To make it multiregional please follow these step by step instructions using your remote control:
1. Switch power on
2. Open the DVD tray (leave it open with no DVD in it)
3. Press "stop"
4. Press "734466"
5. Use cursor to scroll up or down until it says "Region 0"
6. Press "OK/Enter"
7. Switch power off
8. Switch power on
It show now play all region DVD’s. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 30, 2010 | Teac DV-H500 DVD Player
Try to play various DVD's and get "insert disc" message .
This could just be a dirty laser lens. Turn the unit on and open tray. While the tray is open unplug the unit without turning off so the tray stays open. Remove the cover and under the disc clamp is the optical pick up assembly. The lens can be cleaned gently with a alcohol dampened q-tip. The lens should look clear not hazy. If this does not help the whole pick-up assembly will have to be replaced. There are no adjustments that can be made on these, they are factory set. Go to www.encompassparts.com and click on guest log in, or http://servicesales.sel.sony.com (search is in the upper right, make sure to change drop down menu to psrt number) and use this part number A-6062-705-A to get prices.
Sep 07, 2009 | Sony DVP-NS700P DVD Player
DVD player disc tray won't open
take a screw driver and open it up
maybe its a disc that stuck
if not working
probably cheaper to buy a new one
Apr 28, 2009 | Philips DVD793CH Multi-disc DVD Player
Locked dvd tray.
with the unit off press and hold the stop button and the eject button.
Jul 08, 2008 | JVC TH-S11 Theater System
Cannot Close Sony DVP-NC665P 5 disk tray
There is a possiblity that he may have shifted the unit while discs were in it causing the discs to slip off the tray and into the unit. You have to open the unit to check if there are loose discs.
Nov 12, 2007 | Sony DVP-NC665P/S Multi-disc DVD Player
Pansonic DMR-EH55 DVD Recorder,
hi, did you try thr hard reset? sreejith
Jul 24, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder Logo
271 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
