Electronic's ! drivers Power seat module , driver door module . Do you know anything about automotive electronic's ?
The heated seat module (MSM) controls heated seat operation for both the driver and passenger seats. There are 2 modes of operation available for heated seats; both the seat cushion and seat back heat, or seat back only heat. When a heated seat temperature signal request is received, the MSM will activate both the seat cushion and seat back heating elements. When the heated seat BACK ONLY mode button is pressed once the MSM will deactivate the seat cushion heating element and leave the seat back heating element ON.
The adjustable pedal system is controlled by the memory seat module (MSM).
your best bet , have a qualified repair shop check it out ! Could have DTC'S - diagnostic trouble codes in door module , BCM etc...
Well if there is more heating in your heat pump i suggest you uninstall the entire set up and service it once. Its quite possible that it has not been cleaned for quite sometime.
I do believe that there should be a tip switch under the feet and if it is broke off then you need to by pass the switch. You could use a small piece of dowel rod up inside to trip the switch and have heat.
Try this remove the ckt breaker for the power seats the ckt breaker is located in the fuse box inside down by the drivers left foot. leave breaker out for about 10 seconds then reinstall it and see if the seat starts moving. If it does there is a reprogram for this and needs to be done by a dealer or someone who has access to be able to reprogram your vech.
several things could cause your heated seats to not work. If the seat and heated seat seat stopped at the same time could be the reprogram could fix it. If the heated seat quit working at a differant time it could be the seat heater element. get a schematic of the heated seat and ohm the wires for the element. If either element tests open then the element will need to be replaced. You might as well replace both of them at the same time since the seat covers have to come off to replace the seat heaters.(back and bottom ) If one element is bad then both heaters quit working.
It is quite possibly the thermostat. Dont risk your health these heaters are not very expensive and I would suggest going to buy a new one from your local department store.
Based on the limited info.I have, it sounds like the heating element is not getting power. suggest visually inspecting the switch and thermostat for burnt wires. Also check the heating element for broken electrode.
