The printer hangs in the midst of printing then an instruction to shut down the printer will appear and stating that an error has occured
  • 83 Answers
Reset yours printer setting and then and check printing Change data cable and then and check printing if not working means logic card have a problem
Posted on Mar 16, 2011
My epson wf 2630 printer is in an error state I send documents to the printer from my laptop but nothing happens I can not get it out of an error state
If you have sent more than one document that has not printed, you need to click on the printer then see what's
in the print queue and delete all the documents that haven't printed. If documents are "hanging" in the print queue it won't print. Only one document can be in the queue at one time..
Dec 06, 2017 | Epson Office Equipment & Supplies
Printer error has occurred - says to cancel printing and shut off, then start again. I wasn't printing and there is nothing to cancel. Shut down numerous times and won't clear & start.
Brand, model, operating system, source of the error message all help in exploring an issue. The printer was shut down several times and the error message did not clear? If the printer is shut off for a significant time allowing discharge of any capacitors (which are similar to batteries) and yet you get an error message when you power back up, it suggests that there is a mechanical problem or inking problem. This would require troubleshooting of the device. You might find help for that on the manufacturer's site. HP, for instance, has a diagnostic program that can be downloaded.
Sep 01, 2017 | PRINTER Office Equipment & Supplies
Dell3100. Getting PCL error - press reset .tried to reinstall .nothing works
  1. Press Select ( > ) to clear the error on the printer.
  2. Reset the printer NVRAM:
    1. Press Menu.
    2. Press the down arrow until Configure appears, and then press Select ( > ).
    3. Press the down arrow until Maintenance appears, and then press Select ( > ).
    4. Press the down arrow until Init NVRAM appears, and then press Select ( > ).
    5. When Restart Printer appears, turn the printer off and then back on.
  3. Change the PCL driver to binary mode and attempt to print the document again.
    1. Right-click the printer's icon in Printers and Faxes, and then click Printing Preferences.
    2. Click the Advanced tab.
    3. Click Bitmap Smoothing and change the setting to On, and then click OK.
  4. If the error still occurs, Contact Technical Support.
Feb 12, 2015 | Dell Laser Printer 3100cn PCL6
I am getting the error code 13.05.00 on an HP laserjet CP3505n printer. The manual says that it is a front door jam. The jam is occurring every other time I try to print a document. The document is being...
13.05.00 HP CP3505N
Problem Solve. Same error. Generally either a real or phanton jam from the paper tray or manual feed tray.
SOMETIMES the manual feed would work but always one corner on the paper turned down when printed.
Remove toner cartridges and bottom paper tray
Turn printer on its back. The black plastic flap (about 9" long) that hangs down a small amount (near the white main feed roller) had one end most likely the wrong side of the small metal rollers above it.
This flap should hang about vertical. One end of it is most likely the wrong side of the small mostly metal roller above it. Each End of this flap should be about mid way between the two smaller metal rollers.
WITH CARE take a timber skewer and carefully encourage this flap back so that both ends are in the correct place
Sep 02, 2010 | HP COLOR LASERJET CP 3505 N PRINTER
Queue problems and spooling.
By uninstalling and reinstalling the printer software.
Jan 21, 2010 | HP Photosmart D5069 InkJet Printer
Hi, My printer model is TLP 2844.i m facing the problem in printing. The printer is hang after one or two lines printing and red LED are ON and I press Green button repeat same as before. Please solve my...
Solid red light. This indicates the printer is in an error state and will not print until the error is cleared. Check to make sure the printer is not out of labels or out of ribbon if it is a TLP model.
A solid red light will occur if
  • the printer is out of labels
  • the printer is out of ribbon ( TLP models only )
  • the printhead is open, not latched down all the way. Press down on the top cover of the printer to see if the error light clears and goes to green.
  • the ribbon spool is slipping on the ribbon spool holder on TLP models:
These 2 links will help you troubleshoot the problem:
https://support.zebra.com/cpws/docs/eltron/2844/28x4_rib_det.htm
https://support.zebra.com/cpws/docs/eltron/2844/2844_tsguide.htm
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Hanging print queue on Canon iR2200-3300
my ir2200-3300 canon printer m/c ip adders change automatically in 2-3 days pl. solution my problem?my email ID sudesh_trivedi@yahoo.co.in
Nov 20, 2008 | Office Equipment & Supplies
When trying to install software for Lexmark x2580 it seems to hang part way through. Heve tried several times from disc, and downloaded software from Lexmark. Message in bottom right states 'a problem...
Hi ,
Definitely u install printer through connecting printer to pc .that's why the problem is occure........
please uninstall of drivers& software of printer restart pc with disconnecting printer from computer...
then install software for printer ..follow the instruction ..then when pc notify u to connect printer/harware detection then connect printer to pc & get printe on ....i am sure u r printer will be detected & install scessfully done
if this information is useful for u please Rate me.........
Jun 14, 2008 | Lexmark Office Equipment & Supplies
22 people viewed this question
k24674
jasbo
jasbo
