Question about LG GT540 Cell Phone
I insert new SD card in may GT540 lg mobile, but showing status SD card removed insert a new one. i check new SD card is ok. but still it showing message "SD card is not mounted" please help me out.
  • Anonymous Mar 31, 2014
    I have a Kyocera hydro edge from boost mobile and i have a muve music sd card in it i down loaded muve music but it keeps saying learn more or call for help or insert sd card how can i get it to stop and take me to were i can set up an account and start down loading?
  • 83 Answers
Sd card slot damaged. Change slot with new
Posted on Mar 16, 2011
I am connecting My LG gt 540 into my pc, sd card is not open?
OK check to make sure that the SD card isn't write protected, either on the SD card or in the phones settings? Also try formatting it on a PC with a SD USB adapter format FAT16/32 and then put in the phone and if required format again with the phone after which you should be OK, if it still will nor work maybe try another SD card? as that one just maybe faulty?
Oct 16, 2011 | LG GT540 Cell Phone
Phone tells me that sd card is not inserted when there is an sd card inserted
You need a compatible SD card - try formatting the SC card you have. Also be sure it is not full.
Sep 26, 2011 | LG GT540 Cell Phone
I have an LG Optimus M. It says the SD card is not installed. I have 2 of them. I reformatted both and it's still saying that. My computer recognizes both SD cards but not my phone.
Hi Everyone,
I had the same problem, and fixed it by very gently bending the Micro SD pins up a little. See the picture below, remove battery first, get a very small screw driver or other implement and one at a time bend each of the 8 pins up slightly, you do not have to bend them much so be very careful. Make sure none of the pins are touching when finished. So the cause of the fault in my LG Optimus GT540 phone was the pins had flattened and were not contacting the contacts on the Micro SD Card well enough. Which is a bit of a design fault really because my original card stopped working because of this and ended up fried. I done the fix above when the new card I bought and checked that it worked on my computer, but when I put it in my phone would come up with the message SD Card removed.
Hope this helps!
Regards,
Peter
May 24, 2011 | LG GT540 Cell Phone
I have purchased a San Disk 4 G micro SDHC card for my mobile phone - LG GT540 (Optimus) which is also new. The phone doesn't seem to recognise the card. It gives me a notification that SD vard has been...
Hm.. Try using an adapter and access the card on a PC to make sure the card itself actually works. Next I would check the filesystem format. If it's formatted NTFS or something like that, odds are the phone can't read it. Make sure it's fat32 or fat. In windows you can check this after plugging the card into your system by opening my computer.. find the card in the drives menu and right clicking the drive, then clicking properties.
Apr 12, 2011 | SanDisk 4GB microSD High Capacity Memory...
Removed sd card inserted a new card and still showing card removed
Hi There,
It could be that you have not put it in correctly.
The front of the card should face left and then you need to click in the holder.
Simples Squeak
Yours Sincerely
Lewis
Apr 06, 2011 | LG GT540 Cell Phone
I've requested an unlock code from orange lg gt540 which I recieved and used. Brilliant. When I insert my AT&T sim card it only allows me to make emergency calls. There is also a small exclamation mark...
Really brilliant :D, just kidding. I think your phone not yet unlocked, make sure you follow the details instruction from orange how to insert LG GT540 unlock code in your phone. And make sure you got the correct lg unlock code from your network provider.
Mar 30, 2011 | LG GT540 Cell Phone
Hi, i m using LG GT540 mobile. The camera won't work. it ask the SD card. After i put the card, when i go to the camera, its not open. it just blink only. or sometime the message was appeared "sd card...
Sometime this occurs due to the format issue. Did you format the SDcard using Win32 or NTFS? those two are likely the culprits.
If not, it is time to replace the card.
Mar 04, 2011 | LG GT540 Cell Phone
How can i install application in sd card in lg gt540...
if you insert the card into the pc and try from that source and you are unable , maybe it can be installed like that just on the phone, some phone dont give the option to install on the micro sd just on internal memory
Nov 22, 2010 | LG GT540 Cell Phone
Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
Apr 16, 2010 | LG RUMOR Cellular Phone
LG Cookie Won't Recognise Memory Card
it will need to be smaller then 8gb...... also micro SD......... NOT micro SDHD .....you also need to format it using the phone (check user guide for info on how to do this)
hope this works for you .....good luck
Apr 23, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
LG GT540 Cell Phone Logo
1,152 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
