Question about Dell Inspiron 1501 Notebook
I want to disable my mouse pad on my inspiron1501
    Sergeant:
  • 212 Answers
You should find a check box if you go to your Control Panel --> Mouse applet, under the touchpad settings. There should be a checkbox to disable the touch pad.
If not...check your system tray for a DELL touchpad utility or mouse utility running and look for the setting in there.
Posted on Mar 16, 2011
  • 40 Answers
Hi, I never tried to do it that way, but I know that the mouse pad is considered as a PS/2 device, so I guess you could disable the PS/2 devices from your bios at computer startup (Access it by pressing Del, F2, F12, or the key that is beeing shown as "Press ## to enter setup")
Good luck! I'll try that myself soon!
How do I disabled the touch pad and only use an external mouse and the keyboard on the lap top?
You do not have to actually disable the touch pad on this laptop to use an "external" mouse. Just plug in your mouse and it will install the drivers if needed and viola, your good to go. If you insist on disabling your touch pad however, you can do that by double tapping the top left hand corner, when you do this correctly, a little orange light will show and the screen will show a notification the the touch pad is disabled. To enable the pad back on, just repeat the same step you used to disable, and the on screen notification will indicate the touch pad is enabled!
Aug 04, 2011 | Compaq Presario CQ56-115DX Laptop
Have puchased. a acer wireless optical mouse how do I change over from the present mouse pad?
Theres nothing you need to do much, just plug in the wireless transmitter drive into the usb port, then download driver if one is required. Press the link button, usually a small button located under the wireless mouse.. then you should be good to go. You can disable the mouse pad, usually there is a button or a fn key to disable the mouse pad.
Jan 31, 2011 | Computers & Internet
My mouse causes me to have to gets in the retype all the time cause it goes back up in my sentence or highlights my words blue
This is a very common issue with mouse pads build into laptops computer and can be avoid by moving your hands away from the mouse pad (meaning to open more) during the typing process. You might also want to try to disable temporarily the mouse pad by pressing the mouse button sometimes located on top of your mouse cell or pad or, by pressing FN key along with "F's" key(from F2 to F12). There should be a pad with a hand meaning to either disabling or enabling your mouse pointer.
Finally, try to use and external mouse.
Good Luck!!
Jan 11, 2011 | Computers & Internet
How do you disable the mouse pad on an Asus using Windows 7 ?
To “Disable” the Mouse Pad, or (“Pointer Device”), go to the Control Panel; select the (Mouse) in the Hardware and Sound category. Next select the Device Settings, in the (Devices) block, click on, and “highlight the item you want to (disable)” this being the “Pointer Device, this will also disable the “Mouse Pad” Click the “Disable button,” just below. “Always (“click”) on the, “Apply, and OK buttons before exiting.” Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware. “Did this solution help? Helpful Rating Feedback, appreciated, thanks paul7of9.”
Feb 09, 2010 | ASUS Computers & Internet
How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
Dec 30, 2009 | ASUS A6U Notebook
Toshiba satellite a215 disable mouse pad, is this possible.g
I think you meant touch pad. so on every Toshiba notebook Touch Pad can be disabled on two different ways. The first one is using FN+F9 key combination or using DISABLE option in mouse properties.
Nov 26, 2009 | Computers & Internet
Elimnate mouse
You are talking about the mouse-pad or also called track-pad, I don't think we have a spanish name for it. To disable clicking with your mosuepad (a.k.a. tapping) go into your control panel mouse options and you should be able to find an option that reads "enable tapping", just unchech the selection box next to it to disable this option.
Jun 23, 2009 | HP Pavilion dv1000 Notebook
Disable track pad when using wireless mouse?
Go to your control Panel and right click on the "mouse" selection', then go to "Device Select" . Then click on the "Disable".
May 11, 2009 | Computers & Internet
Dell inspiron1501 touch pad sensitivity problem
you are going to have to go into the control panel and to the mouse properties. in there you will be able to put the icon back in the taskbar. i dont know why it changed itself though. on my dell a couple times i had to reinstall the mouse drivers for some reason. i just went to dell.com and got them there. hope this helps
Apr 22, 2009 | Dell Inspiron 1501 Laptop
Dell Inspiron 1501 Notebook Logo
99 people viewed this question
Alun Cox
