Question about Mitsubishi VS-45609 TV
I have a mitsubishi 45"
  • Mitsubishi Master
  • 8,457 Answers
This tv have no colors wheel or projection lamp.Tv only have 3 CRTS tubes like R,G,B CRTS tubes guns.Problems of the tv?Will help u diagnose and replaced parts or telling should be repair by a tv Tech.
Posted on Mar 16, 2011
I have a 2002 Mitsubishi vs45609 that shuts itself off after a few seconds. Is this repairable ?
have you tried replacing the bulb? if you have and the issue exists... yes with the proper parts it is repairable... but i doubt it will be cost effective.
Feb 18, 2015 | Mitsubishi Televison & Video
Wd52525 yellowish color when static. Menu has some pixelation. Colors are off.
It does not matter---these sets are so bad (this one) they sell the entire chassis or the light engine which has the color wheel in it and last time I looked the wheel does not come unless you buy the engine.
May 24, 2012 | Mitsubishi WD-52525 52" Rear Projection...
I need a new color wheel WD52527 where do I get one It has been replaced once already while under warranty and is now doing the same thing
Try website like Tvrepairworld.com have it for $229 Mitsubishi colors wheel.Make sure the same exact colors wheel model as ur tv model ok and u have the skills and know how to do it ur self.These colors wheel are deligate part and can be damage easily.If not sure about it and can or can't do it.Hire a tech. to do it.These colors wheel are spinning at 1200 RMP if u put in wrong the colors wheel 50/50 can be damage the place u buy it from will not take it back.
Aug 30, 2011 | Mitsubishi WD52527 52" Projection HDTV
Convergence problem again
I think you might need to do an advanced convergence. this is done threw the service menu. it is complicated and time consuming. however there is still a possibility that the green convergence circuit has failed. there is very little green correction since it is in the middle. most sets don't even have a green convergence circuit. however this one does. these pico fuses are "tiny yellow" look like a small resistor. chech for b+ on all 3 conv.ic's.
Jan 04, 2010 | Mitsubishi VS-45609 TV
Mitsubishi WS-65611 has a blurred image with the colors creating almost a double image. was told it might be a color wheel. Should i order a new one? Best Buy said it would be a $150 house call to...
The model number you have posted does not have a color wheel at all.
If it is WS-65611 go into the customer menu and select convergence--if it is 3d and will not adjust there--you have a convergence problem.
I HAVE AVAILABLE START TO FINISH, STEP BY STEP INSTRUCTIONS for replacing this part in this set--available here for free.
If someone told you it is a color wheel and you have the correct model number here posted--they are not very smart--this model does not have a color wheel and the later Mitsubishi sets that did have one--they do not sell the color wheel for them.
If you want the instructions let me know and I will post them here for you. I have repaired hundreds of these sets and the instructions are based on actual experience doing this repair.
If this has helped you rate this solution as I do this here for free.
SD TECH
Dec 14, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi TV Model VS45609 Blinking Green Light
I have a Mitsubishi VS 45609 tv. I turned it off at midnight and tried to turn it back on the next morning and nothing happens. Can you help?
Nov 03, 2009 | Televison & Video
Color convergence
The convergence IC's will need to be replaced along with possible resistors and/or fuses.
Dec 17, 2008 | Mitsubishi VS-45607 45" Rear Projection...
No color for first 45 minutes TV is on.
temp sen componet need tech .  to find  comman prob solid state equip.
Nov 30, 2008 | Mitsubishi VS-55707 TV
Mitsubishi 45" Projection TV
You may need to replace the color wheel or the power outage may have damaged the DMD board too
Jan 05, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi VS-45609 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
