Question about Vacuums
I have a gamages sewing machine, and am unable to find any information about it on the internet. It did not come with a manual, and I am not sure what all the setting mean. I have identified the tension control, but there is another dial, with the following settings: R=reverse, F=Feed, 0=not sure what this means. But in this setting, there are other settings you can have i.e. 7, 15, 30... Would appreciate any advice. Thanks
SOURCE: MACHINE WILL ONLY SEW IN REVERSE
I had this problem with the same machine. I took it to a repairman and he found a piece of a broken needle underneath the metal plate where the needle goes down to sew. After this was removed, it worked properly.
Posted on Jul 06, 2009
  • 3230 Answers
SOURCE: Need a manual in English
Well you may please follow the link below to get your manual -
http://www.pfaff.com/global/12893_16350.html
Good Luck!!
Thanks for using FixYa!!
Posted on Sep 22, 2010
  • 1456 Answers
SOURCE: My Huskystar E10 sewing machine
Hello
Remove your needle and reinsert it to make sure it's straight and secure. Make sure the needle is in the "up" position (press the needle position button if it's not), power off the machine, and loosen the needle clamp screw. Pull the needle out and make sure it isn't bent. To reinsert it, push it back up into the clamp, flat side facing the back. Tighten the clamp screw to secure the needle.
The best solution might be a Tune-up of your machine(servicing)..you will have to take it in for a repairer for took things to be adjusted, oiled and set back to factory spec's and it will work fine again
This might cost you about 60 dollars
Posted on Dec 24, 2010
HansPP
  • 2510 Answers
SOURCE: I have a 3 year
This might sound too basic for you but check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out. This might not be exactly the same as yours but should give you an idea of the position.
images?q=tbn:and9gctyfr7tkfpdipppvqt_-ka70owyny1t5tzdw5qtysow1a3fr_qmpji113vk
Posted on Feb 26, 2011
vko007us
  • 254 Answers
SOURCE: need a manual on the
PLZ TRY THIS LINK:
http://homeappliance.manualsonline.com/support/globe/sewing-machine/manual-540-2279952
Posted on Aug 21, 2011
Singer quantum le my sewing machine is frozen and
Check to make sure you do not have a small piece of thread stuck in the raceway area
Aug 12, 2013 | SewShop.com Singer Model Quantum LE...
When I go to the manual category @ Sears and click on Kenmore Sewing Machine Manuals (including my model #), all that comes up are parts...they don't show manuals...where can I find a manual for my...
Here is a link to an online version of the manual. You are going to have to have the updated version of Adobe Reader X before being able to access the Manual.
Here is the link: http://www.managemylife.com/mmh/owner_manuals/2247/KENMORE-Mechanical-Sewing-L0909123?brand_name_search=158.14300+
Hope this helps!
Sep 16, 2011 | Vacuums
How to get Brother sewing machine apart to replace spool spindle.
To be honest the best thingon such instructions is the manual which is provided along with the machines,but many people don't have it , probably because they have lost the manual orthey have got the machine as a used one and forgot to take the manual alongwith it.
Please follow the belowinstructions :-
Close to the end of theHandwheel , there is usually a spindle, at the back of the machine.
This is where you need to restthe spool on and you would notice it sitting perfectly.
In case the length of the spindleis less , then pull it up gently with your fingers.
Also there are machines these dayswhich have easy to replace facilities , so the spindles just slide intothe machine for safety norms when you put the machine away.
Therefore , all you need to do it pullit up and it would be fine.
An example of a manual forbrother's sewing machine can be found in the below link which would give you anidea of how exactly it's done.
http://bit.ly/j2BdsP
Hope this helps ..:)
Jun 11, 2011 | Vacuums
Where can I obtain a FREE Manual for my New Home Simplicity Sewing Machine model #446? Thank You, Rose Harris roseharris2008@yahoo.com
Try posting the machine number and name on the internet and google it, you may get it there or just go to a store that sells this machine and ask them if you can photocopy the manual.
Apr 25, 2011 | Vacuums
I need a manual for a singer 20-33 professional sewing machine. would like to download.
Here is a link to your Manual:
homeappliance.manualsonline.com/manuals/mfg/singer/2320.html
Just click on the SAVE THIS MANUAL button and fill out information.
Jim
Oct 04, 2010 | Vacuums
Sewing manuel for singer sewing machine 9015T
Hi
Try the Singer website. http://www.singerco.com/accessories/manuals.html
Just type in 9015, do not include the letter T and click on search.
A list appears on the next page and a free download is available.
I'm not sure what your machine looks like as you have posted this in vacuums!
I hope it's the right manual for your machine.
Sep 27, 2010 | Vacuums
Kenmore YM-40-35 R Sewing Machine Manual (or copy) wanted. If a manual is not available, I'd be OK with instructions for threading the needle and bobbin and any additional details that an expert may...
Please go through the below document which will give you the help you wanted:
http://www.ehow.com/how_4798790_thread-bobbin-kenmore-sewing-machine.html
http://www.ehow.com/how_5839_thread-sewing-machine.html
http://www.youtube.com/watch?v=1j8e8FvwUlQ
You will also find additional information on every page at the left hand side (Ehow.com) and on the right hand side(Youtube).
Please let me know if you need any additional information or have any information that you would like to share with me.
Jun 10, 2010 | Vacuums
Any info on this machine, as I don't have the manual...
if you have internet look it uop on there.type in brotherboutique.com there dhould be a toll free number you can call.sometimes there will be a phone number on the machine.look on the bottom or on the back
Apr 28, 2009 | Vacuums
I have a sewing machine from Westinghouse Electric & MTG. It has a pending patent, on one of the plates says 1903-1013 but this particular is pending. The style # is 281650, can you tell me a little...
more examples of desirable and collectible early patented sewing machines, and to get more information on antique sewing machines, please visit our sister website www.patented-antiques.com, where we conduct most of our Internet sewing machine sales from.
Mar 17, 2008 | Vacuums
Vacuums Logo
147 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
