Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a Craftsman 1/2 hp opener. Yesterday I had to replace the wormgears. When I tested it before I put the chain back on the motor ran in the down direction for about 2 seconds then back in the up direction for 2 seconds and stopped. It did the same thing once I reconected the chain. I checked the limit stops and it shows that it is about half way between up and down. It is not hitting either of the limit stops and I do not have a laser sensor o the floor. I have also tried holding the wall button down, this does not make a difference. no difference with the remote either.
    President:
  • 3,197 Answers
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Posted on Mar 16, 2011
Testimonial: "wow!!! Its amazing how much better it works with all the parts installed. THANK YOU!"
Garage door moves few inches and stops, springs are fine, sensros are fine.
If it is not blinking when it stops, then the capacitor is blown. Replace the capacitor and it should resolve the problem.
Aug 09, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
Craftsman 1/2 hp chain drive starts to close approx 12" then returns to open. replaced main gears 2 weeks ago everything was working. now its about 6" from full open and will only travel 12" then returns...
Make sure you put the black cup back onthe end of the motor shaft and that it is pressed all the way on.Make sure the RPM sensor is plugged in. If neither of these are theissue, then you probably did not have the motor shaft pushed all theway back when you tightened the coupler after replacing the wormgear. Loosen that coupler up and from the front of the motor(opposite end in which the coupler is on) push the shaft back as faras it will go. Hold it there while you tighten the coupler back upand then try it.
Mar 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Replaced gears in garage door opener now door will move only 6 inches
Feb 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 hp garage door opener, model 139.53970SRT, 8-99 Was working fine, then the plastic drive gear got stripped. I replaced the worm and drive gears and all works great mechanically, except...
Nov 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not close, moves 2 ft & returns
Nov 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
On my craftsman 1/2 hp garage door opener connected to our 20 year old garage door, lately it has been getting stuck only about a foot off the ground, the chain is saggin so that when the garage is open...
It may not be the opener causing the problem.Unhook the opener from the door by pulling on the red disconnect handle. Push the door down or pul;l it up by hand by pushing or pulling on the top center of the door where the opener link hooks to door.See if it moves freely or sticks at the place you described.You could have a door spring problem if the door works ok manually the gear/sprocket in the opener is worn.This is an expensive repair and it might be cheaper to replace the opener.The loose chain could be a sign that the sprocket bearing is worn also.If it is not worn the chain is adjustable at the trolley assembly that slides on the rail.
Jul 31, 2009 | American Gardener Rh30 22" Readyhedger 3.0...
Plug it in, won't run
It sounds like the capacitor has failed on the motor (under the little metal cover). Go to motor shop with old one and test/replace.
Jul 05, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
25 yr+ old Sears opener runs past lower limit
Update: I remembered that I had a problem with the door reversing too much a while back. It was chattering in the tracks and I could not fix it with lubrication and changing spring tension. So I dialed up the down reversing force. This contributed to the jam-up I had when the lower limit was ignored. If I had a lighter force, it may have at least reversed.
After futzing with it I left it alone for several hours. The motor would hum every few minutes. I was considering cutting power to it overnight. I pressed the remote one more time and the motor ran normally to a limit and stopped. I tested it a few times then reconnected the chain and door. Seems fine now. I suspect an intermitten logic board problem. I'll try lightening up the down force and using it for a while.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have replaced the gears system in my craftsman 1/2 hp garage door opener. I pushed the button to test the motor and it went up without a hitch. I then went to push the button again and the door went...
Can you adjust the down-travel? On mine, it's a white nylon screw, on the left side, inside the light cover. Seems like there were instructions for this adjustment in the instructions for the gear replacement.
Dec 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
276 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
