Front loading maytag washing machine model mah8700aww stops during its cycle. the drain pump (34001340) is definately bad and the belt also needs to be replaced, could this be the solution to the stopping during its cycle or what oter problem do you think it could be. thank-you
    Brigadier General:
  • 6,277 Answers
No- I would think that either one of those would be enough!!!
You need to get those fixed first before wondering what else, if anything, is faulty, honestly ;-0)
I can understand the thought behind the question though- it's 'can I get everything fixed in one visit'. Don't blame you!
Good luck,
John C
Posted on Mar 16, 2011
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
Dec 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG NEPTUNE FRT LD WASHER MAH8700AWW,NOT COMPLETELY THE SPINNING/DRAINING CYCLE,LEAVING CLOTHES VERY WET,WE SELECT SPIN CYCLE ALONE FOR EST. 9 MIN., THEN DRY, NEED A FIX - HAVE ONE ?
Check that the pump is operating properly. hold the drain hose over a bucket during pump/spin make sure its a reasonable output from the pump..If not remove and clean your filter, then readdress problem as before, if still no cure then check the pump blades are free.....If all is well and pumping okay then spin should be fine providing the motor is okay......Good Luck.....
Feb 16, 2011 | Maytag Washing Machines
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Washer will not extract in the spin cycle
f your washing machine fills and agitates but does not drain, something is probably wrong with the drain hose or the pump. The fact that the washer fills and agitates tells you that the motor works and the belt is fine (though some units have a separate belt for the pump, and direct-drive washing machines don't have belts.) 1) Be sure the drain hose isn't kinked.
2) Check the tab on the lid that strikes the lid switch; if it is broken, the washer may stop during the drain cycle. Press and release the lid switch. If it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repairperson.
3) The water pump may be broken or clogged with a small article of clothing, or the controls may be broken; call an
Dec 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
My maytag neptune mah8700aww is showing a nd code do i need to replace my pump
I would first check the drain stand pipe to see if it is clogged in any way. You can watch it during a drain cycle, assuming your washer is draining, and see if it backs up in there. The next area I would check is the drain hose itself. Make sure it is not kinked, or blocked either. You can check for blocks by pulling the hose off and running a semi rigid object through it. A close hanger, straightened out will work most of the time. If all is clear, and you are not getting any other codes on your display, then the pump is the next thing to check.
Apr 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Our maytag neptune mah8700aww front loader will not drain and unlock the door. what do i do.
The drain pump os obviously either blocked or gone. Lie the drain hose on the ground to drain by gravity. Then have a look at the pump. This may need to be taken out as I'm not sure if there is a pump filter on this particular model. The door is designed to not open with water in the drum.
Dec 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Stop in mid cycle
HD= No drain.
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Jul 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH8700AWW Front load
I have a maytag neptune front loader (MAH8700AWW) unless I turn the water off @ the faucet the water continues to run into the washer after the load is done .How can I fix this.
Oct 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
