Question about Bissell Vacuums
Bissell 3575-8, suddenly became very loud. I seems to work but it's so loud I avoid using it
Extremely loud all of the sudden.
Hi Donna. The sudden loudness can be caused by dirty filters or a clog. We have a terrific FAQ that'll provide you with a complete list of troubleshooting steps to help you.
Here's the link to the FAQ:
http://www.bissell.com/FAQDetail.aspx?id=1362&cid=ccsocial
Aug 10, 2013 | Bissell Cleanview Helix Vacuum
Bissell 6591 operating twice as loud as before.
Hey Mike! Excessive noise can be contributed to dirty filters or clogs. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1421&cid=ccsocial
Feb 03, 2013 | Bissell 6591 Power Trak Revolution Bagless...
My bissel vaccum got very loud all of the sudden
Your belt may be broken, your dirt cup may be full, or you may need to clean your filters. Look at these areas and you can find addional troubleshooting at this link (just select the type of vacuum you have in the dropdown menu): http://www.bissell.com/faqs/?c=330&sc=345&cid=ccsocial
Jan 07, 2012 | Bissell 3576 CleanView II Bagless Upright...
Vacuum extremely noisy
Mine is doing the same thing and my husband told me to purchase a new beater bar. I suggest you do the same.
May 26, 2010 | Bissell 6594 PowerForce Bagless Upright...
Bissell powerforce bagless extremely loud.
It could be that the belt is worn. You can get replacement belts and the manual here:
Bissell PowerFrorce Belts and Manual
Nov 21, 2009 | Bissell 6594 PowerForce Bagless Upright...
Loud noise??
I have the exact same problem. I've taken the thing apart and cannot figure out what is causing the noise. It's not the belt and it doesn't seem to be coming from the engine. It sounds like the spinning brush is hitting something, but it's not, that I can see.
Jul 12, 2008 | Bissell 6590 CleanView Bagless Upright...
Bissell vaccum problem
Could be plugged, check the hose and at the bottom by the brush roll, the inlet maybe clogged. Also check the filter under neath the dirt tank. There are filters above the dirt container, clean those out. If after that it is still loud, then maybe the motor fan or bearins are bad and will have to be replaced, part #2031214 sells for around $55.
Jan 16, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Vacuums Logo
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
