FixYa.com
Tags:
Sony XM-754HX Car Audio Amplifier
Ground wire
By Kim1 - usenet poster
First:
Can I ground my amp with 4 awg wire if the power wire is 8 awg???
Secondly:
I've an amp fused at 40 amp and another fused at 60 amp...
a sony XM-754hx and a Pioneer GM-X922.  My main wire is 4 awg Phoenix  Gold
about 16 feet long, and I've a distibution block, 1 4awg in and 2 8 awg out.
Is 8 awg wire for the sony and pioneer amp are ok, if the 8 awg wire is
about 2 foot long max?  And I've a 1 Farad Cap.
Thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 11, 2005
Helpful (85)
Reynolds
Reynolds - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
It really depends on the setup you're using.  You HAVE to have the same size
power and ground when conecting to a capacitor.  In other words, the cable
from the + side of the battery to the capacitor and from the capacitor to
the power distribution block has to be the same size as the cable from the
capacitor to ground and/or negative distribution block.  After this, you're
fine.  If you want to run a 4 gauge cable from the + of the capacitor to the
distibution block and then use 8 gauge to run to your head unit or
amplifier, then it's still OK to use the 4 gauge from the - side or the
capcitor and run it straight to ground.
   Eric
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
Outkast0 @worldnet.att.net (Outkast) wrote in
<81pp1i$g @bgtnsc03.worldnet.att.net>:
in that case wouldn't the cabling have to be the same length too?  :)
-Alt
The University of California, at Berkeley
Electronic Materials Science & Engineering
        !!!Defend the twLF at all costs!!!
 !!!Help defeat the enemies of enlightenment!!!
Alpine 7949/H400 combo, a/d/s/ PowerPlate Series,
        CDT HD Series, JL Audio W3 Series, Blood & Sweat
Hardware needed for (pseudo) completion:
        <Edited for explicit content by the Geo Board>  :)
Solution #3
Not Rated (0)
Chandler
Chandler - usenet poster
Rating: 0%, 0 votes
I believe it has to do with the resistance of the different gauges of cable.
If you have significantly different resistance in the two cable you will
have an elecrtirc potential difference.  This will cause current to flow on
one direction or another, thereby discharging your cap every time it sits
for any length of time.  Plus, the instructions on all capacitors say you
need to have the same gauge.  If you don't buy my explanation, you should at
least trust the guys who make and distribute the caps. :)
    Eric
Solution #4
Not Rated (0)
LiZzIe
LiZzIe - usenet poster
Rating: 0%, 0 votes
Does more power and more current draw mean anything to you?? I suspect
you had another problem other than what you think. Were the brake lights
the only ones dimming... err turning off?? Nothing else?? Seems to me
like you had another problem.
Solution #5
Not Rated (0)
Green1
Green1 - usenet poster
Rating: 0%, 0 votes
Seriously. Its kinda like buy a bigger car cuase you brakes don't work on
your current one. Now, I mean I can see switching from a huge old amp to a
newer class D may solve the problem, but that is not the way out. Look for
the cause of the problem rather than getting rid of something affected by
the problem.
*Pioneer/Alpine/RF/Kenwood/Sti­nger/Clarion/MTX/MBQuart*
Solution #6
Not Rated (0)
Grant
Grant - usenet poster
Rating: 0%, 0 votes
<81pc04$90 @bgtnsc01.worldnet.att.net>:
Why does it HAVE to be the same gauge?
-Stalker
-Skeptical
Solution #7
Not Rated (0)
Peter1
Peter1 - usenet poster
Rating: 0%, 0 votes
<< ok, In my opinions I need the cap because my light dim when the music is
loud. >>
<<Get a better battery.>>
this won't really help....  the reason that his lights are dimming is because
his alternator can't handle the load, which passes the load on to the
battery...  going from 14.4 volts down to 12.5 volts is what's causing the
dimming.  battery capacity of any $50 die hard battery should be enough for
system duty... and if it's not, then you probably need a rewound (or bigger
replacement) alternator.
a 1 farad cap will probably solve your dimming headlights problem...  possibly
even a 0.5 farad.  if you've got a little extra money to burn ($20 difference
or so), i suggest getting a 0.5 farad and seeing if that solves your problem...
 if not, get another 0.5 farad and you've got the equivalent of a 1 farad
capacitor with better properties.
my lights dim slightly when i'm pushing my amps, but i just don't give a
shit...  i let it.  8o)
take care,
Mike Kim
Solution #8
Not Rated (0)
Pasty
Pasty - usenet poster
Rating: 0%, 0 votes
Caps are too expensive and I feel that they are not real good value for
money, especially in your set-up.
If your lights dim better off selling your existing sub amp and buying a lot
bigger sub amp, preferably one with double the power.
I will explain why. I bought a Phoenix Gold M50  and used it on my two
10inch earthquake subs.
My brake lights would turn off when i was stationary at the lights!!!! (and
this was during the day without anyother electrical device in the car being
used)
I sold the amp and bought a Phoenix Gold MPS2240  to run the same set-up.
No problems no lights have dimmed ever since!!!!!!!!!
This up-grade cost half the price of a 1 farad cap.
Now i run a PPI A1200.2 and a Adcom 5475 (total maximum rating of 1800watts
rms) in the same car no probs.
later    Jonathon
Solution #9
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rating: 0%, 0 votes
loud. >>
Brian H
Solution #10
Not Rated (0)
Duke
Duke - usenet poster
Rating: 0%, 0 votes
riCh,
is there a big difference in SQ on the XM-752X (blue one)
and the 752EQ (red with 5 band EQ) ?
You were talking about the 752EQ then ?
 I am just looking for a 2ch amp with built-in xovers
on it in $150 range... any other recommendations ?
Right now i got Infinity Kappa 102a, i was about to
order another one but they sold out :( I am using 102a
for my db10 sub right now and i am looking for a second
amp for my front speakers.
I have to get something this week!
Thanks!
Solution #11
Not Rated (0)
Riddle
Riddle - usenet poster
Rating: 0%, 0 votes
Sure. As long as your ground wire is always of equal or greater capacity as
your power wire, you're fine. It's when your ground is too small that the
amp tries to source ground current through other means (i.e., RCA's) and
starts having problems (i.e., noise).
Andrew Krause                                             teamROCS #007
"Shaken Not Stirred"                            akra @toddalan.com
ICQ
uin:1233154
teamROCS Technical Director    www.teamrocs.com/technical/
BuyIQ Category Specialist                                        Car Stereo
www.buyiq.com                           "The SMART Way To Shop"
The Web Site Nerd                                       Internet Publishing
"Nerds Do It More Smarter"              www.thewebsitenerd.com
Solution #12
Not Rated (0)
lawyer
lawyer - usenet poster
Rating: 0%, 0 votes
Stupid fucking people.
"Get a better battery".
That ranks up there with "hey, I got a cold", "get a better napkin".
ICQ
uin:1233154
Solution #13
Not Rated (0)
2Pansy
2Pansy - usenet poster
Rating: 0%, 0 votes
WTF? His amp is drawing more current than it can get, and you recommend a
bigger amp?
Who opened the asylum?
ICQ
uin:1233154
Solution #14
Not Rated (0)
Cato
Cato - usenet poster
Rating: 0%, 0 votes
 Yes that sounds good to me, 8ga is ok because it's a short run and you
probably can't fit 4ga in to your amp. But you should add another 4ga
ground cable from your battery negative post to your chassis, remember
what comes out of the positive side must go in, so try and keep the wire
gauges the same on both sides..
Solution #15
Not Rated (0)
Putty
Putty - usenet poster
Rating: 0%, 0 votes
wow your lights dim with that little current?
do they stop with the cap?
anyhow, good luck
--$riCh$
Only the Best
MTX/Boston Acoustic Pro/Sony Mobile ES/Pheonix Gold
Diamond Audio/AudioControl/Alpine/Stin­ger Pro/Rockford Fosgate
1650 watts to bust your ---, Let DA BOMB Drop!
Solution #16
Not Rated (0)
Powe33
Powe33 - usenet poster
Rating: 0%, 0 votes
IME, the 752 is a sweet amp for teh money.  has good sq, realy puts out
rated power, average efficiency, inexpensive for what u get!
good luck
--$riCh$
Only the Best
Solution #17
Not Rated (0)
LiZzIe
Rating: 0%, 0 votes
What????
Solution #18
Not Rated (0)
Gary10
Gary10 - usenet poster
Rating: 0%, 0 votes
that's a load of crap
using a larger ground is just fine. esp if its a long run.
--$riCh$
Only the Best
Solution #19
Not Rated (0)
Rogers
Rogers - usenet poster
Rating: 0%, 0 votes
yes
u really dont need the cap, and the 4 and 8g combo is fine
--$riCh$
Only the Best
Solution #20
Not Rated (0)
Riddle
Rating: 0%, 0 votes
Hey,  since you got that sony amp can you tell me
what speakers you are powering with it ? how do you like
the amp ? I am thinking of buying the 2ch version of that
amp .
thanks
Solution #21
Not Rated (0)
Melissa
Melissa - usenet poster
Rating: 0%, 0 votes
loud.
$riCh harPer$ <str8 @ibm.net> a ??crit dans le message :
383B5B25.3 @ibm.net...
Solution #22
Not Rated (0)
Jimmy NY
Jimmy NY - usenet poster
Rating: 0%, 0 votes
i @hotmail.com (Mo??) wrote in
<G7J_3.3317$63.61 @news.globetrotter.net>:
  Then you can try a cap!  haha.. but if it STILL dims, and you listen to
it loud all the time, then I'd be lookin at a better alternator ;)
Richard
tR #114
Sony Mobile ES / Phoenix Gold / ESX Quantam Series (soon BayBEE!)
JL Audio / Infinity Reference / Stinger / DEI
Solution #23
Not Rated (0)
Charlie
Charlie - usenet poster
Rating: 0%, 0 votes
If you are using 8 awg for power because you actually need to, then the
ground should definitely be 8 awg. But if the load on the power wire would
have been suitable for a 4 awg wire, then you could use the miss-match you
proposed.
                Mark Hempstead
Solution #24
Not Rated (0)
Joey2
Joey2 - usenet poster
Rating: 0%, 0 votes
  you can put a block on your ground. i use 4 ga. in and 8 ga. out of my
blocks both positive and ground
Can you Help with these Car Amplifiers problems?
Car Amplifiers
car amplifiers
i have a Jeep Grand Cherokee... Answer This...
Car Amplifiers
yjhrt
Car Amplifiers
schematic for washburn pg 65 c
need schematic Answer This...
Car Amplifiers
NASHVILLE DAB35
CONECTARE Answer This...
Car Amplifiers
code for kenwood cd player
I just bought this car... Answer This...
Repair Service
Find Car Amplifier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
