Question about Zenith XBV441
While playing DVD color is not correct and there is a black line down the middle with the image split on either side of the screen.
    Sergeant:
  • 212 Answers
First, verify that your cable from the DVD player to your TV is connected properly and snug. You can try re-seating the cable to make sure all the connections are tight.
If that fails, I would try another input on your TV. If it works on another input, then your TV may have a problem with the input you initially had the DVD Player plugged into.
Third, try another cable, or output type on your DVD player.
If all of those fail, the problem is most likely to be with your DVD player itself, you can either try to have it repaired or replace it.
Posted on Mar 16, 2011
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
How do fix a hitachi tv with a 2 inch black line down the middle
try to play dvd movie first on your tv to see if the problem is on TV or the antenna connection
Jul 18, 2012 | Televison & Video
Permanent split screen down middle by black line
The GPU has overheated that is what causing this problem.
You will need to stop the heat build up and get it repaired - you can even do this with a good guide or send it in.
Nov 01, 2009 | Microsoft Xbox 360 Console
Image split with black bar in middle
check leads if they are connect in the normal video slot on dvd player and chek the player settings what out pot it is on
Aug 21, 2009 | JVC HR-XVC18B DVD Player/VCR
After xbox is turned on the screen is split in half?????
I had this problem with my dvd player. It turned out the solution was to replace the cables. Once I used a new set of cables the problem vanished. This may work for you as well as if the cables get kinked or frayed at all it will not give an optimal connection. Hope this helps you out.
Jul 26, 2009 | Microsoft Xbox 360 Console
Dvd player split screen
I had the same problem. It turned out to be my cable that went from the dvd player to the TV. I replaced with new cable & everything worked fine again. Hope this helps & please remember to rate my answer. Thanks.
Feb 06, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Split screen
It appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Jun 23, 2008 | Panasonic DVD-RP56 DVD Player
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Zenith XBV441 Logo
88 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
