Samsung CLP 300 Laser Printer Logo
Posted on Mar 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I check my toner levels - Samsung CLP 300 Laser Printer
Anonymous
Level 2:
  • Expert 117 Answers
  • Posted on Mar 16, 2011
Anonymous
Expert
Level 2:
Answers
117
Questions
0
Helped
46270
Points
381
Your printer had a LED indicator located on the Top, Right side panel of your printer.
When the Toner LED, on the control panel, indicating each individual toner cartridge according to its color, lights, and the Status LED lights red, the toner cartridge is totally exhausted. Your printer stops printing and you need to replace the Toner.
For more information about your printer, click on the link.
I hope this will be able to help you.
Thank you for using Fixya
My sharp printer is telling me to check toner cartridge, what am I going to do?
Hold down the blue house button on the main menu until the toner levels and meter reading is displayed. Tap the toner remaining tab and the device will display your current toner level.https://business.sharpusa.com/portals/0/downloads/Manuals/MX-M1055-M1205/contents/01-072.htm
How do I get a toner coverage report from a Sharp 2610C?
How do I monitor toner levels in my Sharp copier or MFP? You can monitor the toner levels in your Sharp copier or MFP by pressing and holding down the COPY function key . Two pieces of information will then be displayed.
The Total Copy count on the device
and
The remaining toner levels. This will be shown in 25% increments. When you get down to 25% capacity check to see if you have spare toner on hand. If not, give us a call and we will promptly deliver.
How do monitor toner levels in my Sharp copier or MFP
check out the user manual too:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&ved=0ahUKEwja6dWd9fLMAhXGlx4KHegRC24QFghIMAc&url=http%3A%2F%2Fwww.wisconsinimaging.com%2Fdownloads%2Fmx3610nManual.pdf&usg=AFQjCNEyIj_mysubFXRIlvDoqEKBw3L4zQ&sig2=0jtdA8-CGBc2ej3tWvEdHg
it stated
To view the approximate amount of toner remaining, continually touch the [Home Screen] key ....
Can you reset toner level in Xerox DocuColor 260?
Usualy what i did i use toner chip (100%) fix it to toner cartridge then insert to machine, check the amount if 100% then pull out the toner cartridge and replace old chip insert back to the machine, check it will be 75%.
0F54H Fatal Error
Witam,
An error occurs on the toner level sensor for each color:
0F52H Toner level sensor /Y malfunction
0F53H Toner level sensor /M malfunction
0F54H Toner level sensor /C malfunction
0F55H Toner level sensor /K malfunction
Relevant electrical parts:
Toner level sensor/Y (PS13)
Toner level sensor/M (PS14)
Toner level sensor/C (PS15)
Toner level sensor/K (PS16)
Printer control board (PRCB)
Step Action:
1 Check the connector between each sensor- PRCB PJ21 for proper connection and correct as necessary.
2 Replace the toner level sensor of the corresponding color.
3 Change PRCB.
2helpful
Ir 3570 error e000024-0000
E024 The developing assembly connector is disconnected/Disconnection of Toner sensor.
0000 The connection detection signal is absent
continuously for 100 msec. Replace the developing assembly toner sensor. Connect the connector. Replace the DC controller
PCB.
0001 Disconnection of the wire used for detecting the
connection of the toner level sensor is found.
When the disconnection of the wire used for
detecting the connection of the toner level sensor
has been detected for 7.5 min without
interruption (12.5 min in the manual /envelop
cassette feeding).
has been detected for 12.5 min without
interruption.
-iR4570/3570/3530
cassette feeding).
-iR2870/2270/2230
interruption.
Correct the cable. Replace the sensor.
TRY THIS:
Remove toner and check for broken parts on tube, check the connection of toner assy, reconect all connectors on dc controller pcb.
If you removed the toner assy before the error occcured check if all connectors are properly inserted.
Brother MFC-9840CDW - checking toner level
On my APPLE the MAC OS driver depicts the toner levels when I check the printer status under the settings and preferences - printers icon - supply levels is an optional choice. I have not found a way to check the levels on an XP system.
1helpful
Toner levels
Install Smart Panel monitor for the printer and from the software you can check the toner level.
Check this link if you need any software / drivers / firmware etc....
http://www.samsung.com/us/function/search/resultList.do?searchWord=clp+300
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
