Question about Lexmark Office Equipment & Supplies
202 PAPER JAM OPEN REAR DOOR, CLEARED THE PAPER BUT STILL GETTING THIS MESSAGE
    Problem Solver:
  • 18 Answers
I have had this problem happen to me repeatedly. I am not sure what model of printer you have, but in my case, the rollers needed replaced. I am not sure if your printer is connected to a server or just your computer, but it is also important to keep your software up to date as well, check Lexmark's website periodically for updates.
Posted on Mar 16, 2011
  • 71 Answers
Turn off and back on. If the error is still there, look in different areas of the printer, somewhere there is a piece of paper stuck. Sometimes when clearing a jam, little pieces will get stuck in the rollers and you just need to search for them and remove them to clear the sensors.
  • 4 Answers
SOURCE: 202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Posted on Aug 08, 2008
  • 300 Answers
SOURCE: Keep getting an error message
If you can't see any paper stuck inside the printer when you open the rear door or when you remove the toner cartridge, the rear paper flag is either stuck or broken.
The flag is a small piece of plastic which sits at the rear of the fuser and as the paper exits the fuser it pushes the flag down. The easiest way to see this is to remove the rear door then the rear cover (two screws).
If it's broken you'll require a replacement fuser (i don't think you can get the part separtely), but if you have recently installed a maintenance kit, i would contact the supplier and ask for a replacement.
Posted on Apr 20, 2009
SOURCE: 202 Paper Jam
A 202 error usually means that there is a problem with the fuser, more than likely the fuser exit sensor is jammed - either with a piece of paper, or the return spring on the sensor has stuck. Check this sensor, making sure it can return to the upright position freely. This should clear the problem. If it doesn't, or the sensor arm is broken, a new fuser should solve this problem
Posted on Jul 17, 2009
  • 15 Answers
SOURCE: Lexmark Optra S 1625 202-paper jam open rear door
well with my experience with my opinion crappy lexmark printers there is a senser on the fuser behind the cover it could be jammed down saying there is paper in the fuser when there isnt try lifting it and then flicking it down a few times to work it loose so it springs back all the time and then re-assemble the printer and try it now. hope that works for you had the same problem at work with another model and that is what was wrong with it. good luck
Posted on Sep 02, 2009
  • 15 Answers
SOURCE: the printer message is 202 paper jam open rear
These are the messages got stuck in print queue, you have to release the print queue, First got to Printer and Faxes, there would be your printer icon (Lexmark E342n) Laser printer icon, double click on that, you would see all the messages stuck in queue, release or delete from there. that has to work, please let me know if it works or not
Posted on Nov 01, 2010
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
The printer message is 202 paper jam open rear door. There is not a paper jam in the printer.
Nov 01, 2010 | Lexmark E342n Laser Printer
Rear door paper jam
Here are some articles on rear door paper jam on Lexmark X646e printer. Just click on these links: http://bit.ly/blkK1m ("202 Paper Jam" Message on a Lexmark X642e, X642e or X644e Multifunction Printer) and this link: http://bit.ly/awNDER (A 202.xx (x = any number) Paper Jam Message Is Appearing on a Lexmark X64x Series Printer). These are some guidelines on how to resolve the rear door paper jam on your printer. If you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jul 22, 2010 | Lexmark X646e All-In-One Laser Printer
202 paperjam open rear door. My printer did have a paper jam and we removed all the paper we could find, but that message won't go away and it hasn't worked since! HELP!
Hello and Welcome to FixYa
Start by following the steps below to get the paper out from the machine.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Advanced
If that doesn't help then you would have to start taking apart the machine to find the jammed paper and remove it, its not something a just anyone should do unless you have experience.
you may have to take the machine to a repairer to get the jammed paper bits out of the machine, if you don't see paper jammed in the machine it does not mean that there wouldn't be a paper jam somewhere in the unit along the paper path. Some of the switches or sensors might have gotten stuck.
Jan 04, 2010 | Lexmark T630 Laser Printer
Keep getting an error message "202 Paper Jam Open Rear Door", cannot clear the message. We ordered a maintenace kit maybe 3 months ago.
Apr 20, 2009 | IBM Infoprint 1352 Laser Printer
202 Paper Jam
If you have a duplexer check in there. also sometimes the paper will get stuck in the fuser and will be torn off inside. you can take the fuser out with a phillips (2 screws) and and 2 plugs. check and rotate fuser by hand to be sure it is clean. re assemble
Aug 04, 2008 | IBM Infoprint 1120 Laser Printer
I can not see see paper jam, but it says 202 paper jam open rear door.
i think problem must be in printer see there wheather any paper is jam if jam take out that paper by removing paper manully and then restart the system once
thannks
Jun 16, 2008 | Computers & Internet
202 pam jam
Jun 13, 2008 | Lexmark T630 Laser Printer
202 paper jam error, but no jam present
I cleared that error on one by replacing the fuser. It had a small piece of paper stuck in the roller.
Oct 30, 2007 | Dell W5300N Laser Printer
567 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
