Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
THE SCREEN WAS HIT AND NOW THE PICTURE LOOKS CRACKED WITH LOTS OF COLORS. NO REAL PICTURE. WHEN THE TV IS OFF IT LOOKS FINE. can THIS BE REPAIRED AND DO WARRANTIES COVER THIS OR EVEN EXTENDED WARRANTIES
    Brigadier General:
  • 8,909 Answers
If you have Accidental Insurance Cover on your household insurance or covered by other means then you will be offered a replacement TV. If not there is no cost effective answer as to have it repaired is generally more costly than a replacement item.
Contact and authorised Toshiba service cetre for advice.
Posted on Mar 16, 2011
LG internal screen is cracked after being hit by remote. Outside screen is fine.
If the tv comes on and u see lots of colored line most likely its a goner
May 01, 2012 | LG Televison & Video
One of my kids hit the screen with something. when off it looks fine, but when on the screen looks cracked on the inside, plus there is lines of color running side to side and up and down. sometimes theres...
I hate to be the bearer of this news...but the LCD panel is cracked and ruined. Probably will NOT be worth repair. I have one in my garage JUST Like this, only a few months old, Samsung,and it looks FINE, until it is powered and then you see the "spider web" pattern.
Keep this in mind in the future..flat panel sets are MUCH, MUCH easier to break than the "old fashioned" CRT Sets, that you REALLY had to try and break. A minor "tap", less than needed to break a window, is ALL that is needed to kill an LCD OR plasma set.
Oct 10, 2009 | Vizio GV42L 42 in. LCD Television
My son threw a ball and hit the screen cracks all over can this be fixed with a new screen or is it junk now really bright light shows through all the crack marks
The front glass is just a protector for the LCD screen. If your TV turns on and the picture looks ok (may be a little color variation around the crack if front glass is pushing on it, variation OK black Bad) If the picture looks within the range described then replace the glass. It is just a piece of standard glass and a pretty easy diy job. If the LCD screen is broken the repair will be more than the replacement cost. Sad fact US TV repairmen make a living wage while the workers that assembled you TV wouldn't be able to buy lunch here with what they made putting it together.
Jun 02, 2009 | Toshiba 42HL67 42 in. LCD Television
Screen has a little scratch there is sound but on picture with little thread lines coming form the scratch
you likely need a new tv. on the insides the audio pieces are a lot tougher than the delicate pieces that create the picture for you. if it was dropped and something hit it and it cracked losing your picture, I am pretty sure the tv is toast.
May 19, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Screen color/picture quality
You can access the menu by hitting two buttons on the TV itself at the same time. You then adjust by hitting the up/down buttons.
The double pictures u mention sounds like a convergence problem.
If adjusting the convergence via the menu does not work
you would need to order 2 parts and be able to solder. A rather inexpensive repair if you can do it yourself.
For step by step info on how to repair click below
Good Luck,
Paula
http://techghetto.com/tv-repair/
Jan 14, 2009 | Philips 60PP9202 60" Rear Projection...
My tv has a lot of red color in the picture
Tt might be the problem with he color circuit board, bring it to the repair shop for repair, or if you can do it do re-soldering to any visual crack at the soldered lead terminal of the components on the circuit board and then try put on to check if the problem goes away?
Nov 10, 2008 | Akai PT5492S 54" Rear Projection...
Panasonic 47 inch Projection tv PT-53WX42F
Sounds like your convergence chips are going. Unless you are real handy with soldering iron I would suggest having a tv repair shop service it(probably cost $200-300). If you are handy then I believe the chips you need are Sanyo STK392-110. There should be 2 of them. be careful if you order them online, there are lots of chinese knock-offs out there.
Apr 19, 2008 | Panasonic PT-47WX49 47" Rear Projection...
CRACK LCD TV SCREEN
I had one broken a few months ago. I got a couple quotes.. it was about $200 less then a brand new one. I'd just buy a new one.
For the new TV I'd pickup a screen protector for it. My son threw a toy at my TV the other day and I nearly had a heart attack from the flashbacks. Thank God I picked up one of these a few weeks earlier. It stopped it. LCD screens really break easily as you know. http://www.tv-armor.com
Mike
Mar 16, 2008 | Samsung LN-T4665F 46 in. LCD Television
Three seperate colors on Screen
Screen may have a hair line crack in it causing projection to be distorted. Inspect screen very closly with magnifying glass if necessary to insure no cracks. If crack is found replace screen.
May 18, 2007 | Zenith R40W46 40" Rear Projection...
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
81 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
