Question about Ovens
My bosch stove hgs235uc-01 the oven wont fire off everything else works when i set the cooking mode to convection bake and set temp and then hit start i hear a click but it s not on in the oven the 4 burners on the cooktop work fine
4 Suggested Answers
  • 116 Answers
SOURCE: Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Posted on Mar 11, 2007
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    SOURCE: GE True Temp Oven not heating. Broiler works
    we bought a new oven
    Posted on Dec 15, 2009
    Baking in the convection oven, do you set the temperature 25 degrees lower than the recipe calls for?
    temperature settings in ovens vary make to make
    set around the receipe recommended temp but remember that most on tv cooks always say around the temp ( around 180 or around 250 for about 1hour or about 10 minutes
    When cooking , nothing is set in concrete so to speak
    Jun 04, 2017 | Ovens
    Amana Convection Oven - Not heating in normal bake mode, but works otherwise
    I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
    Jan 13, 2014 | Amana Ovens
    Old kenmore built in oven wont unlock
    When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
    However....."broil" feature works just fine.
    Please help.
    Apr 09, 2010 | Ovens
    My Maytag Performa oven and stove top will not turn on (heat up)
    Please help.
    Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
    I have a Bosch HBN 455 double oven with the convection oven on top, and a regular oven on bottom. The unit is about 5 yrs old. We recently ran the Self Clean mode, and it seems like it has malfunctioned...
    Do you see any Error Message on the Display?
    If not, then it should not be a Concern. More often this could be Thermal Fuse on the Back of the Unit ( On Most Models ) will stop the Broil and Bake from Turning ON. You would just start a bake cycle and the temperature will sit at 100 and something degrees and never raise.appliance.
    Let me know, once you check the same.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Dec 28, 2009 | Bosch HBN 455 Stainless Steel Electric...
    Oven will not heat up on bake broil or convection cook.
    I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
    Jan 18, 2009 | KitchenAid Architect Series KEMC308KSS...
    Dear customer,
  • Test the element
    Jul 08, 2008 | Ovens
    Bosch HBN 642 -- single oven cycles and doesn't get above 325
    WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
    May 28, 2008 | Ovens
    My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
    like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
    Jan 07, 2008 | Ovens
    Amana Convection oven not controlling temp
    I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
    Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
    Ovens Logo
    78 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
