Question about Cooktops
Saeco coffee vending machine reads OUT OF SERVICE 06, it is not blocked
  • sarah jones Mar 11, 2012
    I'm having the same problem with my Saeco SG200 vending machine. After I fixed the jam, it will happen again after a few cups. I have black cams. I need help! Thank you!
    Habit-Forming:
  • 17 Answers
06 means the cup dispensers jammed. Remove all cups and switch the machine on. if the cup dispenser make a clicking sound the the cames in the cup dispenser is jammed and needs to be freeed. if it works theres no clicking noise, switch machine off, and reload the cups in the tube that arn't directly over the cam hole. if this is an ongoing issue, tell me what colour are the cams (theres 5 and there black or white) and describe the cup that your using.
Posted on Mar 23, 2011
Blanco Blanco BCM6X Built-in Coffee Maker manualmanuals
My Blanco coffee machine (BCM 6 X) does not heat or froath milk
Jan 03, 2014 | Cooktops
After 1.5 years, the cooktop stop ignite all 4, plus there is no clicking sound. Do I need to replace the entire ignition block?
Sorry to read about your problem, I hope this helps you out.
you may have a defective control #W10110491 $17.99
Try getting your parts here, www.aplusapplianceparts.com and use this coupon code 1051 for a discount.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Whirlpool 31 in. SCS3017RS Gas Cooktop
The Halogen burner on my 36" GE profile cooktop does not work
either the element is burned out or the control relay is defective,
I suggest you call a service company
If you live in the Denver area i can help you...
Dec 19, 2010 | GE 36 in. Profile JP969SHSS Electric...
Jp989 electric cooktop burners will no longer turn on
Hello, and sorry to read about your problem.
Sounds like you have a general main board failure,
I tried to help you. Please help me and vote/rate my response thanks.
Dec 18, 2010 | GE 30 in. Profile JP989 Electric Cooktop
One of the coil does not work
Sounds like you have a general main board failure or you have a bad inductor coil
Dec 16, 2010 | LG 30" Built-In Electric Induction Cooktop...
Hotplate will not turn on at all.
Dec 16, 2010 | Baumatic 23 in. B10 Electric Cooktop
Front large heats to high
Sounds like you have a general main board failure, or a defective heat sensor
Dec 16, 2010 | Maytag MEC5430BDS Electric Cooktop
One of the burner controls automatically lowers itself to the "1" setting. If I turn it up it goes right back to "1" by itself
Sounds like you have a general main board failure, or a touch pad sensor issue
Dec 15, 2010 | Dacor Millennia ETT304 Electric Cooktop
We use the cooktop for about 5 mins. then it starts beeping
You have a failure that needs to be read by a technician. Call GE Consumer Service 1-800-432-2737 as these guys know the product unlike any other and can translate the fault code (there's more behind that "F" that you won't see until the unit is put into "tech mode")
Dec 12, 2008 | GE Cooktops
Jenn-Air Electric stovetop / oven range SCE4340B - Fuse blown ? ? ?
Andy, sounds like you lost a leg of power. Check the breaker box first. Maybe the contractors tapped an existing breaker instead of adding one for the burner/broiler. You would have to check the terminal block on the range. Should read 120V from each end to center and 220V across the two outer terminals. If you don't have this, something got messed up with the contractors. Catriver..post back
Mar 04, 2007 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
117 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
