Question about Digital Products Brother HL-2040 Laser Printer
HL-2142 Red error light flashing all time - have checked paper and all okay but cannot get it going??? Many thanks
    Guru:
  • 767 Answers
The printer has the paper red light flashing,but it has paper in it.
If the light that is flashing is the error light then check the front cover and the fuser cover to be sure that they are closed. Check for a paper jam. Clean the feed rollers. This can also be a memory full or a print overrun error.
Jul 13, 2011 | Brother HL-2170W Laser Printer
For the HL-2140 Brother printer, the red error
Too many things can cause that, you remove the drum and run the blue tab back and forth to clean the corona about 20 times, the fuser may not be heating and you need a new fuser, Feel for heat in the back door or at the exit, If the drum is used up you open the front door and press go until the lights flash to reset. Make sure the paper tray is fully inserted, this one is picky. You may need a shop to diagnose.
Feb 01, 2010 | Office Equipment & Supplies
HL-5140 model. the paper light is flashing and
Hi Patricia,
Try to do a factory reset on the server.
Whilst the printer is turned off, press and hold the GO button as you plug the printer on to the socket. Notice that all lights on the printer will turn on as well. Continue pressing the go button until the light for the toner goes up and once its up, release the button. Next, hold down the Go button again until the "Yellow Status" light turns on once on, release the Go button. Wait for the printer to initialize and see if the error went away.
Hope this helps.
Jan 05, 2010 | Brother HL 5140 Laser Printer
My Brother HL 2170W printer has red error light on. It was printing something over and over and I wanted to stop it so I pulled (oh, no!) the paper out and then I guess the red error light went on. I...
There is probably still part of the sheet in the fuser at the back of the machine. The fuser will need to be removed and checked for scraps of paper and/or damage to the temperature sensor and v likely a dislodged paper sensor arm.
Oct 15, 2009 | Brother HL-2170W Laser Printer
Red error light is flashing on Brother HL-2040
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000070/faq000170_006.html?reg=us&c=us&lang=en&prod=hl5240_all
Hope that helps,
Tiger720
Sep 13, 2009 | Brother HL-2040 Laser Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Sep 04, 2008 | Brother HL-2040 Laser Printer
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Printing mailing list
Sounds to me like the word doc's page size is not set to the same as your printers tray.
In word, file , page set up. page size/paper size is set to "letter" in US I think is standard, it's A4 in Oz
On printer driver check page size setting too
Contral panel, printers and faxs, RIgHT click on brother printer icon, properties, printing preferences, page size
post back
Nov 17, 2007 | Brother HL-2040 Laser Printer
Digital Products Brother HL-2040 Laser Printer Logo
641 people viewed this question
Top Digital Products Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alan Rothery
Alun Cox
Are you a Digital Products Office Equipment and Supply Expert? Answer questions, earn points and help others
