Question about Invacare Supply Group Invacare Pronto M91 Electric Wheelchair
I have a Pronto M91. When I push the joy stick the lights turn off and the first two red lights blink. I check all the connections and the wheelchair will not move. I would be thankful for any help.
  • 692 Answers
You have low batteries and need charging if you been charging and still get the red lights then the batteries need to be replaced and have the charger checked for correct output. If you have a voltmeter you can check the charger by plugging the on-board charger into the wall set the voltmeter to 200 volts dc and plug the leads into the two outter holes of the charger port located under the front of the joystick. with the charger pugged in you should be reading 27+volts if you aren't getting any reading or the reading is lower than 25 volts then replace the charger or get an offboard charger and try charging the batteries via the joystick charger port Hope this helps
Posted on Mar 17, 2011
Pronto m91
You are getting a motor error code. Check motor wiring and connection to the main control box. Motor may have gotten unplugged when changing the batteries.
Jul 08, 2014 | Invacare Supply Group Invacare Pronto M91...
How to recharge but I get a flashing red light on transformer in battery box. this is a Invacare Pronto M91 Electric Wheelchair
The red light on the transformer/Charger means the charger is bad. Sometimes it can also be battery harness wiring. Most often it is the charger that needs replaced.
Jun 22, 2014 | Invacare Supply Group Invacare Pronto M91...
Light blinks 4 times with two red lights
thats a right motor fault, check connections first and cableing
Dec 12, 2013 | Invacare Supply Group Invacare Pronto M91...
Had the Pronto M91 invacare wheelchair in the Push more for a couple of years. Now My cancer is back and I need the wheelchair. I charged and nothing happen. All I see are a steady red light and a...
You definitely need new batteries. After that amount of time the batteries go bad and the plates inside become sulfated. They are only good as boat anchors now.
It is a easy do it your self repair. There are 2, Group 22 batteries in this model. You want to get deep cycle sealed lead acid, preferably AGM (advanced glass matt) group 22 batteries.
Flip the seating system back by releasing the lever under the front of the seat.Make sure you do not pinch the joystick wiring at the back when you do this.
Remove the black plastic cover.
The batteries will be secured by a strap which you should unbuckle.
Disconnect the plugs to the batteries and note how they are run, oriented and connected.
Pull out the batteries, one at a time, from the base.
Make the wiring connections to the battery , put the batteries back in the chair, plug everything in and you are set to go. Hope this helps.
Feb 13, 2011 | Invacare Supply Group Invacare Pronto M91...
Batterys charged. I turn switch on. all the lights come on. Joy stick doesn't do anything. Pronto m91 (trulffes@asisna.com)
truffles e-mail me at lennieg2000@yahoo.com. I need to know if you are getting any flashing lights on your joystick and are you hearing the brakes click when you move the joystick. Thanks
Oct 18, 2010 | Invacare Supply Group Invacare Pronto M91...
One red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
May 15, 2010 | Invacare Supply Group Invacare Pronto M91...
No power to the controles
sounds like bad batteries or blown fuse which is loacated on postive post of each battery.
Mar 27, 2009 | Invacare Supply Group Invacare Pronto M91...
Invacare Supply Group Invacare Pronto M91 Electric Wheelchair Logo
181 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
