Question about KitchenAid 25.4 cu. ft. Side-By-Side Refrigerator with AquaSense In-Door-Ice and Water
The top of the side by side doors are not even. The right door is higher that the left door. Is there a door height adjustment? Model: KSRL25FXM from Lowes The delivery men tried to fix it but now the refrig. is out of level from front to back and the doors now slam shut Need help! Lowes manager supposed to call us!!!
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: kitchen aid superba side by side doors slam
sounds like a door closure is broken on refrig door, a 2 part door closure(cam). look under door where sits on hinge, freezer door should have as well(use for comparison as to broken or not)
Posted on Feb 22, 2008
  • 330 Answers
SOURCE: Freezer Door Stuck Shut
The refrigerator with 2 doors, the freeze has a electronic magnetite automatic close system, I think your electronic relay got problem, it doesn’t automatic relieve, you can try to unplug the electrical plug see if you can open it, after you open it and plug the plug back and try to close it again, if it is works, that’s great otherwise you have to fix it .
Good luck.
Frank
Posted on Jul 02, 2008
jumptrout51
  • 3361 Answers
SOURCE: How do you level the KBRA22KL? Do the 4 wheels
The rear whells do not adjust.
In the link below,locate parts #44 on your refrigerator and adjust them with a wrench.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=503965
Posted on Feb 07, 2010
How do I adjust the height of frigidaire side by side model # FRS23R4CW5
On the cabinet bottom front right near the bottom door hinges you should see the adjusting screw for the front wheels. On most refrigerators only the front can be raised or lowered. Back wheels are usually stationary. Also you don't want the refrigerator level. It should have some tilt or slope front to back (front higher than back). This tilt helps the doors to self close from a 45 degree angle.
Mar 07, 2015 | Frigidaire Refrigerators
The 2 doors on my Maytag SXS aren't even in the front when they close. The refig side sticks out. The doors are otherwise level and even in all respects. I adjusted top & bottom hin
Hello Joe;
My name is Peter. I am a retired field service refrigeration technician.
This was your first time setting the gap between the doors. So, I will share with you the various ways to adjust the doors gap.
1.) On the bottom of some doors there are adjustment screws for pitching the door left or right to set the gap. This was a good design idea, but there is not locking nut to hold the setting. Opening and closing the door will remove the setting. So, if you have these adjust screws, we will forget them.
2.) Lets try this: Adjust the front leveling bolts. Loosen the top of the door hinges. If the gap is smaller at the top, lower the leveling bolt up on the left hand side. Turn the bolt counter clockwise to raise. Pound on the doors to free them to adjust. If the gap is smaller on the bottom, on the right jacking screw, raise the jack bolt by turning the jack bolt clockwise. Once again, pound on the door to free for the adjustment. Then tighten to top door hinges.
3.) OK, This did not set the gap. The gap between the door is different depending on the model. Determine the gap which you would like to set. Using something solid like pieces of wood (do not use cardboard it will crush), loosen the top hinges, evenly space the wedges and tape them to the door. Now tighten the top hinges and remove the wedges.
4.) Ok, This did not set the gap. Look on the bottom of the door at the hinge. You have a matching set of grommets. These grommets interlock when the doors close to keep the doors closed. These are high wear components. The doors rest on these components. One grommet set may be more warn than the other affecting the door gap
Dec 04, 2014 | Maytag MSD2542VE Side by Side Refrigerator
How do u adjust headlghts on 1991 gmc seirre
adjustment is on the top of the light and the side.
Jun 22, 2014 | 2003 GMC Sonoma Extended Cab
GE side by side doors are not alligned
here is a diagram of the doors and the hinge area. Without seeing myself I can only gusess.
you box could be twiked or not level. The hinge at the bottom could be bent. There top hinge sometimes can have an ajustment that moves the top of the door left and right wich will raise the door a littel. to see if this has an ajustment you will need to remove the top cover of the top hinge and loosen the bolts a little and move the door left and right, if it does have someone hold the door where you want and tighten.
Jan 11, 2010 | GE GSS22SGM Side by Side Refrigerator
Adjustment of the fresh food door.
Normal for freezer door to be slightly higher, The upper hinges can be adjusted to make minor changes and raising the front roller under the rlower door will(or lower the higher side) help align them. It is a trial and error adjustment that takes time to get the best compromise of door alignment to cabinet setting.
Eric
Oct 16, 2009 | Refrigerators
I have a Whirlpool Gold refrigerator w/french doors, model GI5FSAXVY. The door on the right is set higher than the other, not allowing me to open my cabinets above. How do I adjust the height of the one...
you might be able to get a little room
look at the bottom hinge of the door
the one you want to lower
you should see a few spacers between
the bootm of the door and the top of the hinge
as well as being able to lower the hinge pin by screwing it down
Oct 11, 2009 | Whirlpool GI5FSAXVY Stainless Steel ...
How do you adjust the doors to closed completely?
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Sep 03, 2009 | GE GSH22JFR Side by Side Refrigerator
One door lower than other, how to adjust door
The door can be adjusted with shims on the hinge post or by adjusting the cabinet by raising the front corner opposite the higher door. Keep in mind the doors are not designed to be perfectly even.If the difference is the depth of a quarter or less it is good. The seals making good contact all the way around is more important. Eric
Aug 08, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Refridge door does not close evenly on my side by
Top hinges can swing right to left slightly when all 3 screws are loosened under removable cover. Use a 5/16 nut driver. Hinge cover may be phillips, 1/4" or 5/16".However, fridge case must be level left and right first. Level fridge with adjusters behind toe kick cover. Once level, you can adjust gap between doors with top hinge movement. Keep in mind that this is a man-made product and you may not get the doors exactly straight due to lose manufacturing tolerances.
Jul 24, 2009 | Refrigerators
KitchenAid 25.4 cu. ft. Side-By-Side Refrigerator with AquaSense In-Door-Ice and Water Logo
114 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
