Question about HP LaserJet P3005 Printer
Hello. During printing I often can see error message 13.01.00 - paper jam, but really nothing jammed. I have printer HP LaserJet p3005. Thanks
    Genius:
  • 1,089 Answers
Your printer has a misfeeding problem.
It never fed any paper so the sensor never sensed paper and thinks that there was a jam.
Try using the manual feed tray. If that works, pull out tray 2 and clean the feed roller . Is this printer
up to date on its maintenance? The feed roller might have to be replaced.
Posted on Mar 17, 2011
Just found this on another forum:
http://www.fixyourownprinter.com/forums/printer/49328#8
I looked through the flap behind tray 2 and saw the rubber texture had worn away on the middle pickup roller, so it wasn't picking up. Gave it a clean and a bit of a scratch to roughen it up and made sure the paper was sitting up high in the tray to help it pick up. A temporary fix, most probably, but at least now I know the cause
Posted on May 23, 2013
  • HP Master
  • 1,684 Answers
That is correct, the 13.01.00 paper jam error is caused by the paper not feeding into the printer from the paper tray. The paper pickup rollers and separation pad needs to be replaced. This can be done by the user to save a service call fee. The kit of parts you need is called a maintenance roller kit and it is available here.
http://www.ccl-la.com/catalog/product_info.php?products_id=172
I hope this helps, if so please rate our solution.
BuddyMc
Posted on Sep 30, 2011
  • Andrew Stout May 23, 2013
    do you know of any step-by-step guides to replace these parts with the kit you mention?
  • Buddy Mcsparrin May 23, 2013
    Hello Andrew,The roller kit comes with the service manual that has the full installation information.
2 Suggested Answers
  • 224 Answers
SOURCE: Getting the error on my HP 4345mfp - TOP OUTPUT
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Posted on Mar 31, 2010
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
Apr 17, 2013 | HP LaserJet 1020 Printer
P3005 jams
Post the exact error message indicated on the printer LCD. 13.01, 02 paper feed issues, worn rollers or jammed paper inside of paper feed assembly.13.05, 06 fusing assembly issues, broken sensor flag in fuser or worn busing on fusing rollers (fusing assembly will be noisy or making grinding sound.) If this the issue being noisy, the fusing assembly has to be replaced along with one of the drive gears, about a 30 min. of work.
Sep 30, 2011 | HP LaserJet P3005 Printer
13.01.00 Jam in Tray 2 error when no jam exists
Check Tay2 paper sensor flag, located at tray2 pick up roller, its its stucked shoot the fault
Mar 24, 2011 | HP LaserJet P3005 Printer
Jam inside top cover 13.05.00 also change fuser assembly
To remove paper jam. Just remove the toner cartridge and pullout jammed paper. If still coming paper jammed error message. Switch of the printer and the printer will roll over the paper jammed.
Changing of fuser drum is required if the print out came with the black strips. This happens when you print large volume of printing jobs.
Nov 26, 2010 | HP LaserJet P3005 Printer
Having message jam inside rear door and can not find any paper jam
Not all of the paper jam was actually cause by paper. There are also instances that the media is the one that is jammed, causing to display a "paper jam" message.
If you can't find any jammed paper from the unit, you can try inspect the following cause..
1. Trays are loaded improperly or overfilled.
2. Tray 2 or tray 3 is removed during print job.
3. The top cover is opened during print job.
4. The media that is being used does not meet HP specifications.
5. The media that is being used is outside of the supported size range.
Also, try to tun HP toolbox.. on the Paper Jam options, click the Typical Jam Locations... to see the internal paper path and potential jammed locations.
I hope this solve your problem...thanks..
May 28, 2010 | HP LaserJet 2420 Printer
HP Laser Jet P3005 Printer is printing very slow
It is usually dirty and old fuser. It would takes longer time to heat up and also triggering error messages. Try changing that.
Feb 15, 2010 | HP LaserJet P3005n Printer
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
HP LJ P3005 13.31.00 ERROR
As i can understand whenever you try to print with rear door closed printed page should come on top from top output roller however paper gets jammed.
Solution:
Try to print a page using rear door open and it should come out from the rear drop down tray it printed page comes out successfully with rear flap open than paper gets jammed at top due to faulty top output roller.
However if the paper gets jammed at fuser with rear door closed than it is issue with fuser in that case you need to get fuser replaced at the same time replace 20 tooth gear next to fuser.
Thanks and Regards
Neeraj Sharma
Apr 11, 2009 | HP LaserJet P3005n Printer
HP LaserJet P3005 Printer Logo
667 people viewed this question
Seeker5211
Seeker5211
