Question about Panasonic DMR-EZ27K
My Panasonic dvd recorder appear to no longer be receiving TV channels it was working and then suddenly not. I canstill view TV through my TV so Im doubtful that it is an ariel problem and I have checked that noting has faled out and I have also tried the auto re tune and stil nothing
  • Panasonic Master
  • 467 Answers
Sounds like the inbuilt ATSC tuner has failed; if this is analogue only, it may not be worth repairing that. If however it is a digital tuner, it may not be economical nor cheap to replace at component level. It is up to you, if you want to submit this unit to an authorised Panasonic service centre, to get a quote and second opinion about it. At least then you could make a firm decision afterwards.
The DMR-EZ27K was a reasonable model Panasonic DVD recorder, and it's better than their DMR-ES15V.
Nice unit. The cheapest option I can suggest would be if it is an analogue tuner model, simply connect an external digital set top box to the respective inputs on the unit and record the TV that way (assuming the channels are not encrypted with macrovision). It's crude, but it will save you an expensive workshop hassle.
Posted on Mar 16, 2011
Can the Panasonic DMR-EH55 be made to receive digital channels? e.g. via a digital capable TV or a set top box? If not, I suspect it will be obsolete when analogue channels cease this year (in Australia)
If you receive your channels through your local cable company, nothing will change. The DMR-EH55 will continue to work normally.
If you receive your channels with your rooftop antenna you'll need a Digital to Analog TV Converter Box. The unit itself will not receive digital signals directly.
Jan 16, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
Can not get any digital progams now that I have retuned my panasonic dmr-ex75eb dvd recorder. Am not receiving any digital signals
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Sep 30, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Awa dvd recorder dr711 can this be connected to a set top box
If it's like the DR620 it will only receive analogue from the TV aerial. I connect the AV out connections on my set box to the inlet AV on the recorder and watch and record through the recorder's "rear AV input" selection.
Jun 16, 2009 | Durabrand DVD-1002 DVD Player
Record a digital channel while watching and analog channel
Take a red, white, and yellow AV cable and plug it from the AV out of the cable box to the red, white, and yellow In of the dvd recorder (change cable box to the channel you want to record). Then change your TV to the channel you want to view.
Have fun!
-Tha Mp3 Doctor
Nov 23, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
Suddenly cannot record DVD after years
Apologies for the delay in response. Your concern was just brought to my attention.
To your recording, based on your second posting (and would appreciate corrective information where applicable), your system is:
  • Cable provider > Cable Decoder Box > Panasonic DMR-E75V > TV (equipment setup)
  • single coaxial cable > yellow, red & white > yellow, red & white (wiring setup).
With your indulgence, a couple clarifying questions:
  • to watch the Panasonic when you play DVDs, to what channel or source or setting must the TV be set to?
  • to record a TV program/channel, to what channel or source or setting must the Panasonic be set to?
  • what is the brand and model of your Cable Decoder Box?
Initially, pls try:
  • play any known good DVD disc/movie. power on the TV and set to watch said movie;
  • without changing anything on the TV, STOP the playing of the DVD;
  • try changing channel on your Cable Decoder Box's remote;
  • pls post back result(s); or
  • do the above steps again but before changing the channels on the decoder box's remote;
  • try changing/cycling through the different input/source of the Panasonic DVD;
  • again post back result(s).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Panasonic DMR-E75V DVD Player/VCR
Panasonic dvd recorder dmr-ex75
Change the AV settings on the DVD or TV to be the same format. Feeding AV into an AV-S gives B&W
Sep 16, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Record tv with Panasonic DMR-E75V DVD Player / VCR
Not sure about this, but my guess would be that you don't have the correct channel set on the DVD recorder. It has to be the channel that you use to receive your signal, NOT the channel that you necessarily want to record. For instance- if you use channel 3 to receive your signal from dish, cable etc but want to record a program on (hypothetically) CBS which is (again hypothetically) channel 24 from your dish or cable provider you would go to "Prog/Check" on the remote, highlight the "New Timer Program" line and press "Enter", and then use the numeric buttons to select channel 3 (the channel you use to receive your signal, NOT 24, the channel you want to record). You will have to program your dish/cable box to provide the channel with the content you want to record, in this case- 24.
Not sure if that was your issue, but hope this helps.
Jun 15, 2008 | Panasonic DMR-E75V DVD Player/VCR
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Mar 08, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Panasonic DMR-EZ27K Logo
120 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
