Question about Belling 924 Dual Fuel (Electric and Gas) Kitchen Range
Hi, I have a Belling country chef 924, (8 gas burners, 1x electric fan oven & 1xelectric grill on the left side , 1x std electric oven on right,) Recently the fan oven and grill stopped working suddenly- moments after turning the fan oven on. The grill has no heat generating from the grill element. The fan oven makes no noise, there is no indicator light operating and no heat generated when turned on. The std. oven does still operate fine as do the burners and the clock/ timer, the clock shows nothing other than the correct time and the timer can be set as normal. Is there a seperate fuse for the left hand side of the oven? Many thanks. Jon.
3 Suggested Answers
SOURCE: looking for grill element for belling 924
Im selling a grill element for 100 dollars very very cheap!
email me at JLweatherkid@gmail.com
Posted on Nov 01, 2009
SOURCE: I have a Belling Country Chef 924. The grill is
the back of your switch for the grill is burnt out you need to replace it
Posted on Jan 03, 2010
What are the dimensions of a chef baroness integra gas wall oven
You need the Chef Model number, then click on the model and then on 'More'.
chef integra baroness wall oven 92 60 chef Compare Cheap chef integra...
Chef EXC627W Wall Oven
Compare prices $849.00 Chef EXC627W 60cm electric fan forced wall oven with separate grill and 60 minute timer in white Separate grill 60 minute timer Easy clean formed shelf supports Cooler door temperatures with air cooled door Wall installation Cooling fan Oven size (cm): 60 Oven - internal dimensions (h x w x d) (mm): 376 x 475 x 432 Separate grill - internal dimensions (h x w x d) (mm): 216 x 475 x 432
Specifications Style of Oven
Separate grill/wall
Oven Type Electric
Width 888 mm
Depth 595 mm
Height 573 mm
Or contact them direct
Welcome to Chef
https://www.chefappliances.com.au/Explore Chef's range of products! ... The simple touches that make Chef functional and easy. Fingerprint. Anti-fingerprint. A special stainless steel finish means our ovens stay free of messy prints. Cooktop options. Gas, electric solid or ceramic. image 1. Boils faster than gas? Easy. The Induction cooktop provides modern, ...
Apr 08, 2018 | Ovens
How to replace selector switch on a belling country chef,the switch is ok but the shaft to the knob has broken
I have a country chef half gas and half electric ,the shaft has broken of half of it is in the control panel and other half is in the knob. How do I get a new shalf and how do I put it back on ,I would be very grateful for your help please message me.
Apr 30, 2014 | Belling Ovens
Hi our fan works on the oven but no heat any ideas what this could be
mine is the same been told it is the heating element that needs replacing
Feb 09, 2011 | Belling 924 Dual Fuel (Electric and Gas)...
Belling oven & grill not heating ,element been testing by electrician and seems to be ok, fan and lights working
hi you dont mention the model but all bellings have a thermal cut out (Limpet stat) the formats have one on the right hand side . remove the side panel to get to it . other models may be at the back, Also can be under the hotplates if freestanding cooker. look for a button sized cylinder 15mm dia 10mm deep with 2 wires connected. or follow a common wire back from the elements( one of them will go there).
Nov 20, 2010 | Belling Ovens
My Belling oven has no heat, but the fan &
If the fan is working o/k, then there is little doubt that the oven element has failed.
This is quite common with fan assisted ovens.
The element is usually located at the rear of the oven compartment behind a removeable cover.
Mar 29, 2010 | Belling XOU252 Electric Single Oven
Looking for grill element for belling 924
Nov 01, 2009 | Belling 924 Dual Fuel (Electric and Gas)...
Belling 924 Dual Fuel (Electric and Gas) Kitchen Range Logo
143 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
