I loose my audio driver - Computers & Internet
  • 83 Answers
Restore yours window restart computer press F8 start window in safe mode when window on in safe mode the desktop appear popup screen y/n press No restore screen appear start restore window or install appropriate driver for it and restart pc.
Posted on Mar 16, 2011
Loose video and audio drivers after reboot every time.I reboot into safe mode to reload the drivers and when I reboot normaly no video or audio.
This might sound silly but first thing to check is your CMOS battery and possibly change it out. I believe those take a CR2032.
Jun 28, 2010 | Asrock K7S41GX Motherboard
No audio device
The "No Audio Device Error" message is usually displayed by your computer when it does not detect any properly working audio device attached to it. You will not hear any sound from your computer when this message appears. Only the internal speaker of the computer can provide you bleeping sounds.
When this message appears on your screen, you will need to first check your computer's BIOS and ensure that the audio is set to "auto" mode. You should also check if you have installed the correct drivers needed by the audio device attached to your computer in order for it to work properly.
Audio Device Drivers The most frequent cause of this problem is an incorrect audio device driver that has been installed by the user. In order to double check if your driver matches your device, refer to the user's manual that came with it to look for its type and specifications. The audio device driver for an onboard device should be provided along with the chipset drivers in the CD that accompanies the motherboard.
Use the Device Manager You can use the device manager to ascertain if the audio device drivers are installed properly. To go to the device manager, right click on the My Computer icon, then click Properties, click on the Hardware tab and then Device Manager. If any device is marked with a yellow question mark, it is an indication that the required drivers are missing. It should be instantly clear if the audio device is truant.
Loose Connections on the Motherboard You can open your computer and directly look at the information written on the audio device itself. While doing this, make it a point to check all connections by ensuring that everything is properly plugged in its correct place. Sometimes, this error is also caused by loose connections and a sound card that has been improperly attached to the PC.
You can download the latest updated drivers from the manufacturer's website, either from your own computer or another. If you have used another computer, you can use a data storage device to bring the drivers to your machine and execute the software installer from there. Ensure that the driver you have downloaded is compatible with the operating system installed on your machine.
Is Your Audio Device Defective? If problems with your audio device still persist, you can opt to test the audio device on a different machine just to see if it's in good working condition. If it still doesn't work on a different machine, you have a defective audio device. You will need to get it replaced if it is under warranty or purchase a brand new one. Remember that you should buy the audio device that is compatible with your motherboard. In addition, don't forget to ask for the updated software drivers of the audio device
May 18, 2010 | Computers & Internet
My speakers are on but sound does not come out, There is beeping noise when turned on to full. Any help?
Well, you don't loose your sound, you loose your sound card setup and driver, you need to reinstall the audio card in another slot PCI, ( if is a external sound card) and install again the sound card drivers. If is internal sound, onboard audio, you need to go into BIOS and disable, and reenable the audio card, and reinstall the drivers. it should work
And Thanks.
Mar 10, 2010 | IBM ThinkPad R40 2722 Notebook
Sony str-DE435 Flash Protector
this is not a reset problem, you have a defective audio output, is either the outputs transistors or the drivers IC's ( integrated circuit) and sometimes if you are lucky is just loose connections on the drivers IC;s.
good luck
Jun 18, 2009 | Sony STR-DE435 Receiver
Problems with audio after installing radeon hd 2400
This happens because the video card has hdmi output. Since hdmi output can carry audio signals also, the audio driver gets disabled. Uninstall audio driver and video driver both, install the video driver, and then install audio driver. after installing the audio driver, in playback and recording devices choose choose the audio output device you purchased along with the computer. This should fix the issue.
Revert back for any clarifications.
Warm Regards,
Zulfir Sadat M
Apr 12, 2009 | Diamond Multimedia Stealth RADEON 9250,...
Hello sir
Here you go sir:
http://www.soundcard-drivers.com/
You only have to choose the company and model
Good Luck
Rate
Jan 20, 2009 | Computers & Internet
Dell E1505 internal speakers not working
You have verified that the sound card and drivers are working, by plugging in externals. This leaves only the speakers. Check and clean the speaker connections, they will sometimes work loose or get a little dirt/corossion build up. If the connections are good, then you will need to replace the speakers.
Jul 30, 2008 | Dell Inspiron E1505 Notebook
Loose shift key....any advice on fixing it?
O.k. first the key. Most likely the retainer has come loose. Take the key off and check the if the retainer is broken, if so, then you will need to contact Compaq support for a new one. If it's not broken, take the key off the retainer, put the retainer back on the board, and place the key in it's general position and press. It will snap into place. If you can't figure out how they retainer fits, then take another key off, be careful to just remove the key leaving the retainer. This will give you a view of how the retainer goes on the board.
Now for the sound. You must do this in order to get the sound working with XP:
This model of Presario has an audio controller that supports
the high definition audio. You need to have Microsoft Universal Audio Architecture (UAA) bus driver for high definition audio installed on the computer before installing the audio driver.
Here is the link for the Microsoft Universal Audio Architecture driver that need to be installed before installing the audio driver:
ftp://ftp.hp.com/pub/sof...4000/sp33867.exe ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33867.exe
After installing the UAA driver from the above links you have
to restart the notebook and then install Conexant high definition
audio driver from the following link :
ftp://ftp.hp.com/pub/sof...4500/sp34200.exe ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
Installing the audio drivers may result in an error, but continue
with the following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "audio device on high definition audio bus" and click update driver.
3. Select "install from a list or specific location"
4. Click next. Then select "don't search, I will choose the driver to install"
5. Click next and then select "sound, video and game controller" from the list.
6. Click next and then click have disk.
7. Click browse C:swsetupsp34200 folder and select the .inf file and click open and continue with the on screen instructions.
Jul 26, 2008 | Compaq Presario 700 470024-192 Notebook
Audio Problem
not sound or after installed with several driver sound but sound not active
Jun 24, 2008 | Asrock P4I45GV R5 Motherboard
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
