Question about LG GD510 Cell Phone
Battery back up problem - LG GD510 Cell Phone
  • 83 Answers
Yours question not proper
Change old battery with new
Posted on Mar 16, 2011
Dead Battery?
Take out the batteries. Also take out the backup battery. It is a button battery beneath the screw in the battery compartment. Check the button battery volts with a multi-meter. After 5 minutes put the button battery back in and then the fresh batteries. It might work now. Alternatively take out a battery, then hold the clear button and put the battery back in. Then try to turn on. If it still does not work take out a battery press the del button and put the battery back in.
Feb 06, 2014 | Texas Instruments TI-83 Plus Calculator
Forgot bios password laptop
Turn laptop off, unplug power and battery, use a screw driver to get back plate off. Then unplug the CMOS battery. Put battery back in, turn laptop on. Turn laptop off. Plug cmos battery back in. Put battery back in and when you turn laptop back on again password should have reset :)
Sep 05, 2013 | Alienware PC Systems Computers & Internet
How to change battery my one touch horizon glocumeter.
The OneTouch Ultra uses a three-volt lithium battery. When this battery requires replacement, you'll see a flashing message on the display screen. Changing the battery should take you less than five minutes.
  • 1
      Turn the OneTouch Ultra off, and then turn the unit over to view the back.
    • 2 Push the plastic tab on the battery cover upward. This unhooks it from the unit. Pull it off to view the battery.
    • 3 Lift the battery out of the OneTouch Ultra. Set the new battery in its place. Make sure the "Plus" sign faces upward.
    • 4 Place the battery cover back in place and push it to snap it back on.
  • Nov 27, 2011 | Exercise & Fitness
    How do I get to the battery to change it?
    Remove the bolt at the back of the passenger seat, lift the back of the seat, and pull it off. Remove the bolt at the back of the driver seat, lift the back of the seat, and pull it toward the back of the seat. Remove the bolts on the battery cover, the battery cable bolts, and lift the battery straight up out of the battery box.
    Dec 15, 2010 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
    I have a Majestron quartz pocket watch. How do I replace the battery?
  • Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
  • Remove the circular watch battery out of the back of the watch.
  • Take the battery to any department store or watch store and purchase a new replacement battery.
  • Insert the new battery into the back of the watch.
  • Screw on or push on the back of the watch. Set the watch to the correct time.
  • Aug 23, 2010 | Watches
    I want to change out batteries
    1. Lay the watch upside down on top of a towel or cloth on a flat workspace. Use a small flat head screwdriver or blade to pry under the watch backing, then lift the backing from the watch. Slide the battery cover to the side to access and remove the battery.
    2.Take the battery to any electronics store to purchase a replacement. Bringing the old battery will ensure you install the correct type of battery in your Fossil watch.
    3. Replace the battery and the battery cover. Apply pressure to the backing until it "pops" back into the watch.
    THANK YOU FOR VISITING FIXYA
    Aug 05, 2010 | Fossil Dress - Analog Glitz Red Dial Watch
    How is the backup battery charged and or changed
    Remove top (side thumbscrews)
    remove main battery cover and battery
    unscrew stylus holder from back (1 screw)
    unscrew black plastic inner top (4 screws)
    remove top gasket
    unscrew back (6 screws)
    carefully remove back
    CAREFULLY NOTING THE POLARITY OF THE PLUG:
    carefully unplug connector from back
    unscrew plastic cover over the speaker & backup battery from inside of back cover (4 screws)
    replace battery w/ Digikey #P084-ND
    23x2mm 3volt 30mah lithium battery ~$6 USD in 2010. aka Panasonic #VL2320/VCN
    this requires you to re-solder the ex. leads to new battery*
    *WARNING ASSUMES YOU ARE ABLE TO CHECK THE POLARITY AND KNOW HOW TO SOLDER SMALL ELECTRICAL COMPONENTS.
    YOU ARE ON YOUR OWN HERE AND ASSUME THE RISKS THAT THIS TYPE OF GADGET HACKING ENTAILS!
    (Optional - find an original replacement battery from Panasonic with the correct leads attached and just plug it in. This is much safer.)
    Reverse operations and you are back in business.
    Jan 26, 2010 | Panasonic Toughbook CF-P1
    How do I replace a SIM card in a Nokia 2115i?
    firstly turn off your phone then open the battery back cover which easy just slide then take out the battery and you will see the sim card holder take out old sim card and put new sim card then put battery back and put back cover.
    Dec 30, 2009 | Nokia 2115i
    Back ups battery rpo1100 APC disconnects the Dell PC power button
    try plugging the pc directly into the wall...if it works the UPS is defective.  You can order new batteries for the UPS online.
    Battery Planet.com
    Mar 13, 2009 | APC Back-UPS Pro 650 UPS System
    When should I replace my backup battery?
    The back up battery should be replaced immediately upon seeing the message "Backup Battery Very Low - Your back up battery is very low or missing. Data loss may result from failure to replace the battery very soon. Consult the manufacturer's instructions for directions on replacing or charging the backup battery." Warning: It is important to note that the back up battery in the MobilePro 900 is not rechargeable, thus, to prevent data loss, it is important to change the back up battery immediately when this message is displayed.
    Sep 14, 2005 | NEC MobilePro 900 Handheld
    LG GD510 Cell Phone Logo
    27 people viewed this question
    Top LG Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
