Question about Maytag Atlantis MAV6000 Top Load Washer
Water won't stop running in at end of cycle, keeps filling up and overflows
    Brigadier General:
  • 6,277 Answers
This is symptomatic of an intermittent water control valve- sometimes closes too soon (its physical fail position is closed) or sticks open too long.
It needs replacing! Service call ;-0(
Good luck,
John C
Posted on Mar 16, 2011
5 Suggested Answers
  • 958 Answers
SOURCE: fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Posted on Oct 19, 2008
SOURCE: GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Posted on Mar 27, 2009
  • 5 Answers
SOURCE: Washing machine does NOT stop filling w/ water!
If the m/c keeps filling, where is the water going ??? if the m/c doesnt reach the required water level it will not start, check the drain hose at the back, make sure its at least 24" above floor level, if it lower then it will just empty as quick as you fill it on gravity.
Posted on Nov 19, 2009
marka19
  • 1430 Answers
SOURCE: Kenmore Heavy Duty 80 Series Extra Capacity Plus
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on Oct 30, 2010
Testimonial: "I had already figured this out before viewing this message. I found that the pressure hose had fallen off of the water level pressure switch."
Why does the Water valve keep running water when bowl is full?
Because the shut off point is above the overflow tube. You will need to either adjust the arm or bend the float end of the arm downward to make the arm end swing higher to reach the shut off point prior to water overflowing into the tube.
Apr 27, 2014 | Korky Waterwise Toilet Fill Valve 528Z
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
Machine keeps overflowing during wash cycle
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
May 20, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Machine does not stop filling with water. Will
Sep 30, 2009 | Washing Machines
Water Overflows from washer
Hello,Sounds like a problem with either the inlet valve or the pressure switch, way to determine which on is while it is filling pull the plug..if water keeps filling it's the inlet valve..if it stops filling it's the pressure switch..If you have any other questions or concerns please feel free to comment again..good luck!! Mike
Aug 18, 2009 | Kenmore Washing Machines
Ge wbsr washer overflows...
Could it be ...this happens only when it is overloaded or the load is out of balance. Please clarify.
If this is not the case .. the water level hose running from the outside tank to the water level switch is likely not making a good seal (otherwise the water level switch itself is bad). Sometimes with age the hose forms a crack in it near or at the end where it connects. This could happen at either end of the hose. Also if you have removed the control panel recently (for any reason) you may have (not knowingly) pulled the water level hose loose from the water level switch. Just slide the hose back onto the tube of the switch before putting the control panel back in place and all will be fine after the first filling of the tub (it may take one filling cycle to build the needed vacuum back up in the hose). Unless of course in the process you have broken the tube off the switch where the hose goes on. In this case replace the switch.
Jun 05, 2017 | GE WBSR3140DW Top Load Washer
Water keeps filling!!
sphion effect while the water comes in the water goes out ..because you never said that it overflows,,,so just put your drain hose up the height of the machine before it can go down,,,drain hose to low...onthejob
Nov 16, 2008 | Frigidaire FTF530FS Front Load Washer
Water Just Keeps Filling!
replace the water inlet valve, the valve that the black hat and cold lines connect to
Apr 19, 2008 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Maytag Atlantis MAV6000 Top Load Washer Logo
380 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
