Question about Ricoh Office Equipment & Supplies
I have a dsc224 or ricoh 1224c whit sc672 error
    Guru:
  • 1,833 Answers
according to your problem error code it means communication error to control panel at station.
And sc also means waste toner full. So first Turn the copier off, wait 30 seconds, and turn it back on again. It may not solve your problem then look in the back opposite the sorter or inside the machine there is a white plastic container, It may be full of toner.
If you find it full of toner then
first empty it out. If it doesn't solve your problem then Check the controller stall,controller board installed correctly with operation panel connectors. After that enter in the service menu and press the SP mode button,open the front door,turn off the copier,unplugged the machine.Wait 30 seconds again. then plugged the machine,close the front door and turn the copier on. Do the all job carefully and step by step. this may solve your problem.
Posted on Mar 16, 2011
My ricoh aficio MP3351 machine has a error problem SC672, plz kindly tell me what i can do???
SC672 occured when controller-to-operation panel communication error at startup After powering on the machine, the communication circuit between the controller and the operation panel is not opened, or communication with controller is interrupted after a normal startup.
.Controller stalled
.Controller board installed
incorrectly
.Controller board defective
.Operation panel connector
loose or defective
Make sure that the MBU is seated correctly. If not, SC672 occurs look at the picture to see what im talking about.
Sep 29, 2017 | Ricoh Office Equipment & Supplies
Dsc224 color print misalignement
This model is infamous for this. Not a job for those without experience.
Aug 27, 2014 | Ricoh 1224c 1232c Gestetner DSC224 DSC232...
Imprimente ricoh afico 1224c sc670
SC 670 - Engine response error.
After powerig on the copier machine,a respons is not received from the engine .possible defect controller board or SBCU installed incorrectly.Try reset the code to turn ON/OFF the main power switch.
Mar 01, 2013 | Ricoh Aficio 3232c 3214c 1232c 1224c Oil...
Hello i have ricoh aficio 1224c color . but the is have problem error sc792 . please help me best regards Salar
SC 792 :Finisher error .
The machine does not recognize the finisher , but recognizes the relay unit .
Possible causes :Defective connector
defective cable
incorrect installation
Aug 10, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh (Aficio) 1224c. code sc670 we want to decode this codesc670
Hi, it looks like a bad controller board. Try resetting it from in service mode with 7807. Also if you can view or printout the error history with 5990-004 for further trouble shooting. Hope this helps
Aug 03, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh 1224c Error SC-421 Please help
Hello!
Well, that is not an easy error. Your machine is detecting a short circuite in the discharge plate. It could be just a defective harness between the High voltage supply unit and the BICU.
So... The best advise i can give you is to call your technical support.
Jul 12, 2011 | Ricoh Aficio 1224C Black and White Copier
I have aficio Dsc224 and i used wrong towner color i used aficio C1224 by mistake and the machine not work propebly ..
The toner for Ricoh 1224C and the Gestetner Dsc224 are the same. Here is a link to show you that the toners are the same for this series.
Good Luck and Thank You for using Fixya.
WheatlandServices
http://www.precisionroller.com/search.php?q=1224C+toner
Dec 21, 2010 | Gestetner DSc224 Copier
Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Jun 18, 2008 | Ricoh Aficio 2015 Copier
73 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
