Question about Car APS921 Remote Starter - Keyless Entry
Elvatoe/PROOE4BS - works fine but the some of the round and oval buttons fell out. Can the buttons be replaced? Sue
3 Suggested Answers
  • 27 Answers
SOURCE: REMOTE STARTER NOT WORKING COMPLETELY
Here is page 2 of the owners manual, Hope it helps.
This will not start the vehicle if any one of the following situations exists;
The vehicle's hood lid is opened.
The gear shift selector is not in Park.
The brake pedal is depressed.
The safety control switch is in the Off position.
1. To start the vehicle, press and release the transmitter button two times within 2
seconds. The vehicle will start and remain running for the pre-programmed 5,10,15,20 minute run cycle. As a visual indication, the parking lights will flash or remain on depending on the setting by your installation center.
2. When you arrive at the vehicle, turn the ignition key to the ON position (not the spring loaded start position), then step on the brake pedal to disengage the remote starter. The
vehicle will continue to run, but now on it's own power.
NOTE: The engine will stop running before the pre-programmed run cycle has expired if you perform any one of the following functions;
-Press and the button on the keychain transmitter two times within 2 seconds.
-Depress the brake pedal.
-Open the vehicle's hood
-Place the unit in the safety control disabled mode.
PRLED SAFETY CONTROL SWITCH
The Push-Button LED control switch allows you to temporarily disable the remote starting function of the system. This recommended whenever the vehicle is being serviced. To place the system in the service mode:
1) With the system disarmed/unlocked, and the ignition switch off Press and Hold the PRLED on.
2) Turn the ignition switch on, off, on, off, on, off.
3) The LED begins to flash two short flashes followed by one long flashes and continues this pattern until returned to normal mode of operation. This puts the unit into the R/S Override mode indicating that the remote start is in the service mode and will not start from RF or any other input Posse or otherwise.
To Exit R/S Override Mode
1) With the system disarmed, Press and Hold the PRLED on.
3) The LED turns off indicating that the R/S unit is fully functional one again
Posted on Dec 18, 2008
SOURCE: I bought a car with this starter (below)and no one
I'm not sure about trunk but to start the engine press twice green buttun and engine should start and to shutt it off press green button once.
Posted on Jul 22, 2010
Remote starter not working elvatoe APS2K4SAW
Factory remote start or aftermarket ? What the hech is this elvatoe APS2K4SAW.If it isn't factory , get it out of there .
Feb 23, 2015 | 1997 Pontiac Sunfire
Does a 99 sunfire have oval or round speakers?
Open your trunk look for the speaker wire's should lead you right too the speaker's then you should be able to determine if they are oval or round.
Good luck hope this helps!
Nov 28, 2014 | 1999 Pontiac Sunfire
Elvatoe prooe4bs
I found this to be a battery problem in the key. Had a new battery fitted and problem fixed. The immobiliser works in very close proximity of the key and so it allows the car to start but there is not enough power in the battery to transmit to the receiver for the locks.
Jun 05, 2013 | Car APS921 Remote Starter - Keyless Entry
Circles do not display as round, they are ovals instead. I just received my computer back, after the hard drive was replaced. Before that, the display was fine. I'm sure there is an adjustment somewhere,...
You should have 4 silver buttons on your screen. Menu,- , +, and select. Click menu, then image control. I know this is going to seem strange, but go to "clock" and adjust it. i am positive it will work. :)
Jun 26, 2009 | HP w1907 LCD Monitor
Button fell off phone.
No, you will have to replace the entire keypad or just stick it using some super glue. Don't take the phone apart.
Mar 24, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Lights don't blink for remote start
If you look at the unit (probably installed under the dashboard, on the drivers side) You can see the wires going into the unit... Follow the wires back and you will find that 2 of them have in-line blade style fuses, it sounds like the fuse in the parking light output wire has blown. if you find the fuse is blown, replace it and the parking lights should be on again when you remote start it.
Jan 03, 2009 | Car APS921 Remote Starter - Keyless Entry
Car APS921 Remote Starter - Keyless Entry Logo
130 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
