Question about Indesit W 123 Front Load Washer
In a previous house, we had both a hot water feed and a cold water feed. My new house only has cold water feed, can i still use this washing machine?
    Brigadier General:
  • 6,277 Answers
In a word- YES!
You will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end screws into the cold water supply and the hot and cold washer pipes screw into the double end. The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
Good luck,
John C
Posted on Mar 16, 2011
There is nothing to indicate that the machine heats the water. We thought by connecting the y piece and just using cold, it would only be cold water. .
Most new washing machines only require a cold water feed! You should only connect the cold water feed and leave the hot water feed disconnected and turned off at the valve.
Mar 19, 2016 | Washing Machines
Can i connect to a cold water feed, i do not have a hot feed
I am assuming you can select water temperature on your machine. Simply hook up your pipe to the cold water feed on the machine, and leave the hot water feed alone. Always select cold water on the machine before beginning a load. If it makes you feel better, cap off the hot water inlet on the washing machine.
Nov 27, 2012 | Washing Machines
Only hot water is coming . cold water none
Ensure the hose's at the back are in the right places, Could be you or the fitters has put them in the wrong place.
Feb 20, 2012 | Kenmore Washing Machines
Can we operate our WFS1273BD washing machine on cold water only? We are on instant gas hot water and have gone through a 45kg bottle in 3 weeks. We have lived in this house before and the washer is the...
ABSOLUTELY! Purchase a 'Y' adapter from your local hardware store and attach the hot and cold lines on the washer to the 'Y' attached to the cold faucet. You won't be able to wash in warm or hot without changing the hoses, though.
Aug 17, 2011 | Washing Machines
Hot water fills very slow(30 MIN OR MORE TO FILL) good water flow from spicket to washer, screens are clear. sewems to be something with the washer its self
Might be a bad inlet valve. To confirm, swap the hot and cold hoses to your washer so that the cold water feeds the hot water connection and the hot water feeds the cold water connection. Turn off both hot and cold water faucets. Set the washer for a warm water wash. Turn on the cold water faucet, and check the flow. Then turn off the cold water faucet, and turn on the hot water faucet and check the flow. If the cold water flow fill slowly, then the problem is with the inlet valve.
It an easy part to obtain from an appliance supply house. To install disconnect the hoses to the back of the machine, and remove the back panel to get access to the valve. Should only take a couple of minutes to remove and install. Hope this helps you.
Oct 26, 2010 | Kenmore 24032\24036 Top Load Washer
I have 4 year old Hotpoint washing machine with hot feed and cold feed. have moved to new house with only cold feed. Will it still work? Do I need to plug the blank hot feed on back of machine?
It Will work ...However you will need a Y piece connector both hot and cold hoses connect to this costs around £2.. ..A cheap fix..
Feb 08, 2010 | Washing Machines
Im instaling a 2 yr old zanussi aqua 1000,it has a hot and cold feed,there is just a cold feed at the house
http://www.4ourhouse.co.uk/cgi-bin/product.pl?PID=213690&brand=&model=&part=y-piece&style=washerhelp
Washing machine is a hot and cold fill, but I only have a cold water supply You can use a Y Piece connector (external link 4Washerhelp spares) to connect the hot and cold fill hoses to a single cold water supply. The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may be able to buy this part also from a DIY store like B&Q)
Oct 21, 2009 | Washing Machines
Cold water or cold & hot water connection?
If there is only 1 water connection on the back of the machine then it's a cold water supply only and the machine will be fitted with a heater element to heat the water. If it has 2 water connections then you need the hot supply and should ask someone to fit the correct isolation valve on the capped pipe so you can fit the required hose. Most modern machines are cold water only.
Apr 11, 2009 | Bosch Washing Machines
Indesit W 123 Front Load Washer Logo
117 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
