Question about Kenmore 64802 Top Freezer Refrigerator
LEAKING INSIDE DOWN THE BACK AND UNDER CRISPERS, AND ICE FORMING INSIDE
    Problem Solver:
  • 5 Answers
The drain hole / drain tube in your freezer are probably blocked or even frozen shut so that the defrost water is leaking into fridge. See my answer here:
http://www.fixya.com/support/t8706684-water_leaking_inside_refrigerator
Posted on Mar 19, 2011
Water inside refrigerator
Because your model has an evaporator located inside the fresh food compartment it also will have a drain opening below that evaporator. This is a common problem with these dual evaporator models that have drain blockage caused by ice or gunk blocking the drain and causing water to flow below the crisper drawers. Sea Breeze
Nov 19, 2013 | Samsung RS275AC Refrigerator
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
My fridge is leaking water down the back into crisper
The defrost drain is stoppped up. The easiest way to solve this is with a compressed air tank. At the back of the ref. at the bottom you will see a hose leading into a drain pan.Blow the air through the hose and it will unstop the drain.Hope this helps !
Sep 29, 2017 | Whirlpool GT1SHTXM Top Freezer...
Water puddle forms on the floor in front of my GE TBX18SISERWN frig
lokk under the crisper draws,if there's water under them you have a blocked drain in the freezer.if there's no water under the crispers check the pastic water lines going to the water valve and the ice maker.if it's the drainyou have to pull everything out of the freezer,remove the inside back wall of the freezer and melt out all the ice with a hair dryer then you have to clear the drain,i use a steemer to do this,you can use a turkey baster or anything will push air down into the drain hole,pour hot water into the hole and when the water goes down the drain you'll know it's clear.before you start you can advance the timer into defrost to help melt out the ice or shut down the control or unplug it,you don't want it to be running while you take it apart.hope this helps you figure out where the water is leaking from.
Sep 24, 2011 | Refrigerators
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Water under the crisper bins in the refrigerator -
Replace the door seal on the freezer. When they go bad, outside air leaks into the freezer and when it kicks into automatic defrost, the ice crystals melt and run down the back of the refrigerator. The oldar models had a drain under the crispers that drained into a pan near the condensor coils. It was a heat source that evaporated the water. Some brainstorm decided they weren't necessary.
Feb 13, 2009 | Whirlpool Refrigerators
We have water under our crispers in our white-westinghouse refrigerator. How can we fix this?
You have a stopped up drain. The drain is located in the bottom of the back of the freezer. Go in thru the inside of the freezer, remove the back panel and you will see the small opening in the back bottom. It will be frozen up with ice also. Defrost the ice off the drain and try to get hot water to pour down the drain until the drain is clear. I use a flexable piece of hose to blow through the drain until the clog is gone. This will eliminate the water leaking down under the crisper drawers. Good luck and I hope this will FixYa.
Mike
Sep 24, 2008 | Refrigerators
The back part of the refridgerator inside where the cold air comes out is leaking water and the back inside wall is wet?
You should fine a drain line just below the freezer level in the back. The drain line is more than likely plugged. Check the loop seal down by the drain pan under the back of the refrigerator. It may be restricted at that point. It may require a complete defrost of the freezer to clear the ice formed in the drain from a back-up.
May 28, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking from freezer down back wall inside fridge
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
May 07, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore 64802 Top Freezer Refrigerator Logo
88 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
