Question about Trendware TRENDnet TEW-432BRP Cable/DSL 802.11g 54Mbps Wireless Router (NETWTEW432BRP)
I have to reset the router almost every day now I have had it for quite a few years TEW_432BRP I don't turn it off at night or my modem just my computer It was working fine until about a week ago and I have had to reset it twicce in the past two days. Is it time for a new one ?? Thanks BRD
    Prodigy:
    An expert who has answered 500 questions.
  • 674 Answers
Its purely normal, nothing to do with your device. Just dial to your ISP and explain your issue.
Try using some Internet Optimizer for proper configuration of your system for Internet.
thanks
Posted on Jun 28, 2011
Hi
you can try speed test here
http://www.scanmyspeed.com/
Posted on Apr 27, 2011
    Sergeant:
  • 223 Answers
Thank you for using FixYa
You may be fighting an internet connection slowdown or shut down. The modem is looking for that connection and if it falls below a certain speed it shuts off. You might contact your ISP first and see if they are having issue in your area, and you can also test your speed at Speedtest.net. If t he internet is good ,then the modem may be bad and last resort, replace it.
I hope this was useful and please comment if this was helpful to you.
Posted on Mar 16, 2011
I dont have installation driver
Router does not require driver to be used, all you have to do is to install the hardware and configure it.
1. You have to know your hardware version, so you can download your materials.
There are 5 version of your TEW-432BRP.
2. Click the link below, If you already know the version.
(Main).
(TEW-432BRP D1.2R/D1.3R)
(TEW-432BRP D1.OR/D1.1R)
(TEW-432BRP C1.xR)
(TEW-432BRP Bx.x)
(TEW-432BRP A1)
3. Download User Guide and Easy Go CD Files.
4. User Guide will help you to configure your router from start to end.
If problem persist just post and give a brief explanation on the problem.
Hopefully this helps
Thank you for posting.
Jul 09, 2011 | Trendware TEW-432BRP Wireless Router...
Can't assess password to set up a new computer
Here is the PDF file that shows how to reset the router if the password is forgotten.
http://downloads.trendnet.com/TEW-432BRP/FAQ/FAQ_TEW-432BRP.pdf
Oct 14, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
Reset password
What password are you referring to; Wireless Security or Web password to access the Router's interface?
If it's the 2nd; Open http://192.168.0.1 (default IP) on your web browser, type username: admin and Password: password. Click on Password then change the default password.
If it's the 1st; Open http://192.168.0.1 (default IP) on your web browser, type username: admin and Password: password (put you correct password if you change the default password).. Click Wireless on the left, Enable Encryption WEP or WPA; for WEP 64 bit you will have to use 10 HEX, meaning 0-9, A-F (e.g. common is phone number). If WPA; password can be set from 8-64 characters long.
Angel .
Jun 30, 2010 | Trendware TRENDnet TEW-435BRM 802.11g...
How to connect tew-432 brp to MT800 modem for a wireless connection
you can connect your Ethernet cable from tew-432brp to MT800.
if serial ethernet cable not work you can check with cross cable of ehetrnet also.
Mar 30, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
Wireless router unresponsive, no activity lights.
Yes ofcourse.its a hardware problem
better u have changed over and try it
Oct 25, 2009 | Trendware TEW-432BRP Wireless Router...
I have a Pre-owned TEW-432BRP router, when i hook it up to comcast modem i cannot accsess internet. My PC says i have a connectivity problem. The button on front of router seems to do nothing, The lights...
There is a reset button on the back of the router. Push in with a paper clip, till the lights flash. This will reset it to the factory defaults.
Then shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line.
Here is the user guide:
http://downloads.trendnet.com/tew-432brp/manual/ug_tew-432brp.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
May 09, 2009 | Trendware TEW-432BRP Wireless Router...
TRENDnet TEW-432BRP router cannot obtain IP through DHCP
it seems that ur PC & cable modem configuration is ok, now the problem is with ur router WAN interface configuration. the problem would be one out of 2 - first to check whether ur router wan interface is configured properly to obtain IP address from DHCP (if possible, u can give the static ip address with same series as cable modem) second to check with ur ISP.
Mar 19, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Can't get Trendnet TEW-432 router to connect to internet with motorola modem
I had this same problem. I was going to go ahead and call ATT and ask them to put my modem into bridge mode, but I messed around a bit more....
I went ahead and turn on PPPoE...tried to run the set up again. Well it worked. Not the internet connection is working through the modem. For some reason, the setup changed PPPoE back to DHCP Client, but it's working now. Give this a shot before calling ATT if you like. Good luck.
May 13, 2008 | Trendware TEW-432BRP Wireless Router...
My TEW-432BRP doesn't work when loggin yahoo mail or microsoft update web!
what are the setting on the router and or pc and modem? Do you have any firewall or portforwarding turned on? Are you using DHCP?
Need more info...
Jan 13, 2008 | Trendware TEW-432BRP Wireless Router...
Trendnet TEW-432BRP
What exactly is the problem? Are you using Cable or DSL internet? Did you connect the cable from the modem to the WAN port on the router and the computer to the LAN or 1 port on the router?
Jan 07, 2008 | Trendware TEW-432BRP Wireless Router...
Computers & Internet Logo
134 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
