Question about Refrigerators
My 10 year old whirlpool GT19DK regfigerator rattles loudly when the condenser kicks in. The unit cools and freezes OK, just loud. The condenser is tight but is the condenser going?
  • Refrigerators Master
  • 43,501 Answers
Here is a tip that I wrote about the clunkingor thumping in refrigerators...
Refrigerator Clunkingin back
heatman101
Posted on Mar 19, 2011
Whirlpool Refridgerator less than 2 years old Making loud buzzing noise this eve so I turned the cooling dial down to off. It stopped the buzzing, but now that I have powered it back to level 3 it will...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | Whirlpool Refrigerators
Loud rattles in front fan and loud hummiing from unit itself along w minimal cooling and freezing up
Unfortunately sounds like the squirrel cage in the front may have broken off at the hub. This is a pretty extensive job on most window units, not all that costly (parts wise) but quite a lot of labor.
Apr 19, 2011 | LG Goldstar GWHD5000 wall/window Air...
All of a sudden our refrigerator freezer and refrigerator stopped freezing and cooling.. The fan is working, cleaned the coils, but when the compressor kicks on it only runs for about 10-15 seconds before...
UNPLUG and remove the compressor relay...if it rattles when you shake it..its bad, if not, it could be the compressor..it takes alot of specialized training and tools and material to replace a compressor. Its not a job that can be done by the average person..
Jan 28, 2011 | Maytag MBR2256KES / MBL2256KES
Cat number ED25TEXHW00, side by side, Whirlpool Refrigerator. Neither fridg or freezer will cool. Lights turn on & condens fan runs. Compressor will not kick in. What to look for???
If the compressor will not kick on what you have is either a bad compressor or a bad starting device. Generally the unit will try and start and after 8 seconds or so you will hear a loud tick. That indicates the relay is bad. If the compressor is bad it will usually make a loud humming noise.
The start device is plugged into the side of the compressor. Unplug the frig. You can simply take off the wires to the start device (remember where they go!!!!!) and pull it off. You have two piece, the overload and the relay. The relay is the piece that is most likely the problem. Some machines will have these put together in a white plastic block. You can shake this entire piece and if you hear loud rattling it is broken. Sometimes the relay is visibly burned and blacked where it plugs into the compressor. Anyway, if you do not have this white plastic relay/overload combo, the relay is a brown square shaped plastic piece. Shake it and see if you hear rattling. If not, chances are very good the relay is ok, and the compressor is locked up.
Compressor changes are expensive and unless the frig is extremely nice and cost a pretty penny, they aren't worth fixing. Relays and overloads should not break $100 for the parts, and any tech should be able to change one in under 10 minutes. So if it's a relay fix that puppy! good luck :D
May 30, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Not cooling at all and loud humming
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
May 13, 2010 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
Window air conditioner loud when compressor kicks in
Possible that compressor motor internal mountings broke.
Apr 07, 2010 | Heating & Cooling
heatman101
Mar 23, 2010 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
Kenmore top freezer, Refrierator shuts off with loud clunk.
It sounds like you may have a compressor that is working hard against high pressure due to a dirty condenser or a condenser fan not running or blocked. If all is well otherwise, the mounting springs inside the compressor may have broken or are weak. The only fix then is a new compressor.
Jun 22, 2009 | Kenmore 64802 Top Freezer Refrigerator
Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
May 30, 2009 | Refrigerators
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
