Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
How to fix light not going off in refrigerator
  • 1,543 Answers
Replace the main pc board. Was part # 6871JK1011C, with a 5 amp light relay, now should use the new board, part # 6871JK10011F, with a 16 amp light relay, which will prevent relay contacts from welding themselves together. Should also replace the lamp socket harness with part # 6621JK2003B which now has a thermostat on it to prevent lamp from overheating and melting lamp cover. Contact a locally authorized LG servicer or LG directly to have the servicer replace this for free, even though technically it is out of warranty, LG will cover the repair. (servicer may need an authorization code to get credit from LG)
Posted on Mar 16, 2011
  • Prem Mulberry Apr 13, 2011
    A good source for LG refrigerator service manuals is here:
    http://steprightupmanuals.com/refrigerat...
My model 106.53206202 compressor stops working about every six months. The interior light lights so there is power. I unplug the power cord and when I plug the power back in the compressor works fine. ...
I think the defrost timer/control board is hanging up...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 09, 2011 | Kenmore Refrigerators
The change filter light didn't go off after changing the filter also
after changing the filter try holding the the lock and light button for 4 to 5 sec this should reser the filter light . mm feed back pls and thanks for ysng fix ya .
Oct 21, 2010 | Jenn-Air 42" Side-By-Side Built-In...
My top freezer refrigerators freezer works fine but the refrigerator part does not cool. It is only 2 years old. Any ideas?
t probably needs a defroster timer. You can take it apart and clean the contacts with some sand paper to fix the old one. It's located just behind the light bulb2_bing.gif. You will have to lower the cover for the light to get to it. Defrost the top freezer2_bing.gif by leaving it off for a period of time or take the shelves out and blowing hot air into the rear vents until ice melts. Then reinstall timer and plug back in. Get the whole model number and go to appliancepartspro.com to get a diagram. I fixed mine in less than an hour. frt18il6dw
May 27, 2010 | Frigidaire FRT18B5J Top Freezer...
Refrigerator section light broke. Replacement
Immediately when you open the fridge door the light has to go on,if it is a screw bulb,just tighten it little while'
if pin bulb push it harder,finally you may have to change
the bulb handle in the fridge.
May 12, 2010 | Maytag MTB2176 Top Freezer Refrigerator
Light issues
lights are controled by the light sw . ck them or replace them . / some times the lights are not in tight. remove the light and use some pam on the base and reinstall . if buld is good .... mm
Apr 18, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Temperature going up on refrigerator, inside light going off
Many things can cause this problem...This fridge is computer controlled. there are tests you can run to find out what is going on.....It may help you isolate to the area of the problem...Getting parts could be hard....
Most service personnel can't fix this fridge because it's too complex...
Here a link to the service manual PDF
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Apr 09, 2010 | Samsung RB215LASH
Frigidaire is freezing everything
Make sure the light is going off when the door is in the closed position. Find the switch that the door makes contact with when it closes. If the light is not going out the heat from the light being on could cause such a problem.
Aug 25, 2008 | Refrigerators
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
278 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
