Question about Epson 450W Projector
Image is not rectangle but it is not a typical keystone issue as it is square on left side and top but low on bottom right and skewed low on top right. It is a school projector on a mobile whiteboard, supported by an arm.
  • 442 Answers
Try moving the screen right hand side away or towards the projector to correct the trapezoidal look on the right hand end
Posted on Mar 16, 2011
Hitachi ceiling projector image skewed. Its narrow at top and gets wider at the bottom
This is called the keystone setting, using your remote, it's somewhere in the menu functions. Since you didn't post a model number & I'm not psychic, :) I can't find your manual to give you more specific instructions! Here's a youtube video for an Epson
Manual keystone correction using an Epson EB 1775W
Dec 07, 2016 | Hitachi Office Equipment & Supplies
Image on an angle
check the lens mirror, my be some angle is broken.
Nov 08, 2013 | Dell 1510X Projector
I have a panisonic pt-lb50ntu Projector. It will only focus the center of the image. When you adjust the focus to the bottom of the image the top and center are out of fucus. The same goes for focusing on...
Is the picture a perfect rectangle shape on the screen. If not then either adjust the angle of the screen, or use the keystone function on the menu to correct it.
Does it still not focus correctly after doing this
Nov 12, 2010 | Panasonic PT-LB50U Multimedia Projector
The whole projection is not square when projected onto the screen. How do we square it up?
if it looks like a trapezoid, you need to keystone it. you can either use the keystone buttons on the top panel or go into the menu under the image adjustments and select the keystone feature.
Jan 13, 2010 | InFocus LP640 Multimedia Projector
Screen is not a true square: One verticle side shorter than other
Simply just manualy adjust the bottom of the screen by adjusting the distance by an inch or so.
Depending on what screen you have adjust it from behind or vith a thin thread
May 19, 2009 | Optoma HD70 DLP Projector
Hannspree HF229H monitor and Windows XP. Images stretch to fit.
I had this same issue.
Go into the monitors menu, go down to "Image Settings", go to "HDMI Mode", select "PC Mode"
Hope this fixes it for you. It worked for me.
Feb 16, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Slanted Border- Projector image is not square
Is the image slanted on the bottom as well?
Make sure the projector's throw is pointed directly at the target ie. screen or wall etc. there's not much else it could be.
Jan 10, 2009 | InFocus ScreenPlay 4805 Multimedia...
Projection issue
sounds like you might need to change the KEYSTONE settings
Nov 14, 2008 | Sanyo PLC XU35 Multimedia Projector
Plc-xu30
This is called "keystone adjustment". If you still have the owner's manual, it will describe how to do it. If you don't have the book, look on the button console on the projector, or on the remote for an icon that looks like a rectangle that is either narrow at the top or narrow at the bottom and press it. That will get you in the control. If there's no button, you will probably find it on the set up menu. It's pretty easy to do the adjustment, one way makes the image narrower at the top, the other makes it narrower at the bottom. Some older projectors just have a **** on the unit that changes the angle of one of the mirrors inside to accomplish the same thing. The reason for this adjustment is to compensate for the distortion of the image caused by a projector mounted near the ceiling and pointing down at the screen, or sitting near the floor and point up at the screen.
Mar 10, 2008 | Sanyo PLC XU30 Multimedia Projector
Epson 450W Projector Logo
358 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
