Posted on Mar 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I print, there are two line balck lines and two faded black lines running down the middle of the page.
Anonymous
Level 2:
New Friend:
  • Expert 47 Answers
  • Posted on Mar 16, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
47
Questions
0
Helped
6342
Points
168
I think it is a laser printer.
In laser printer when the drum got damaged (inside the cartridge ) may leads to this state.
so check it out.
Anonymous
Level 2:
New Friend:
  • Expert 114 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
114
Questions
0
Helped
34742
Points
372
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
1helpful
Line down one side of page.
One of the ink nossels are blocked you can use benzien or hot water to unblock them
Faxes are printed with a line running down the
If the line is on the back you need a shop to replace the ink absorber and put in a mylar shield to keep the ink from coming back up on the rollers.
Old canon copier prints thick balck line down right side of paper
tthis is really old 25 years plus. replaced the drun cartridge which also contains the toner good luck canon sr tech
2answers
Repeating wide smudgy horizintal line across my printed pages
I had the same problem, replaced the PCR in the cartridge, the small black drum that pre charges the drum and erase the old image.
After that print was all back ok.
Regards
Color lines/dashes at top and middle of page when printing.
Amand321,
Your problem lies with the fact that you manually refilled your cartridges. This is not recommended by any technician I know and your solution is in the replacement of all your cartridges with genuine brother consumables. It is going to be expencive, but it is the only real solution.
Gremlin11
Vertical fading lines
Sounds like dust on the CMY ribbon. Did you try a new color CMY ribbon?
Possibly the printer has dust floating around on the inside, but if balck prints good, that may not be.
- techwaredit
2helpful
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Automatic Allignment Problem
Your balck ink printhead is clogged with buit up ink. Manually clean it with cotton buds and proper cleaning solution, right doen where cartridge sits and the contact area the ink part of cartrigde contacts. Try printing now. Did you reset ink levels too?
k24674
ADMIN Andrew
ADMIN Andrew
