Hoover nextra error code eo2 - Washing Machines
    Brigadier General:
  • 6,277 Answers
This is symptomatic of an intermittent water control valve- sometimes closes too soon (its physical fail position is closed) or sticks open too long.
It needs replacing! Service call ;-0(
Good luck,
John C
Posted on Mar 16, 2011
Error eo2 on drier
This error refers to the thermistor or the thermal fuse opening. It needs to be replaced as there is no way to reset it.
Oct 11, 2015 | Hoover VHC68B White Condenser Tumble Dryer...
Hoover Nextra HNWF 3135 door will not lock
1) test the switch door, you do not have error code.
see the video, and replace for defective switch, or loose wires or broken, or burn.
God bless you
Jun 28, 2012 | Hoover Nextra HNWF 3135 Front Load...
Error code EO2 displayed on washing machine
Error E02: Not filling with water or slow to fill.
Jun 03, 2011 | Hoover Washing Machines
I have a hoover washing machine vhd9123d and error E02 keeps showing up. Filter seems to be clean etc.
e o2 is a not filling with water error have u checked the lines going into the machine as well as the water valve? please remember to rank how this post helped and write back for futher questions thanks again
rickead1
p.s. u can also goto this site and it will help you diagnos your machine http://service.hoover.co.uk/fault-finder/FaultFinder.aspx?Section=11
have a great day
Aug 17, 2010 | Hoover Washing Machines
Error message EO2 on heater
EO2 is a high limit code. If you have good flow to the heater you will need to check the by-pass assembly inside the water manifold on the side of the heater. All it means is the water inside the heater is getting too hot and probally not moving threw the heater fast enough. good luck.
Apr 13, 2010 | Pentair Mini-Max® 100 Above-Ground Heater
Nextra is shaking itself to bits and extremely
sounds like the bearing has gone possibly taken out the drum support to shaking could also be one of the wieghts has worked loose.
Mar 15, 2010 | Hoover Nextra HNF 3157 Front Load Washer
My hoover nextra shows error code 03 what does this mean
download a manuel from internet it will tell you it is free
Dec 14, 2009 | Hoover Washing Machines
Programme problems hoover nextra megaload
I had this problem soon after I purchased mine. The engineer came out and readjusted the dial. Hope this helps.
Feb 26, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Program don't start, flashing ligths (start and "delay start" button) for 5 times.
What does the error code mean do you have any idea Is it mentioned in the Hand book. At any rate logic suggests a watewr supply problem that the first thing a washing machine needs - water. So a tap not turned on a Kinked hose An inlet valve solenoid failure- Three things for you to check
Jul 31, 2007 | Hoover Nextra HNWL 3136 Front Load Washer...
Washing Machines Logo
202 people viewed this question
Top Washing Machines Experts
