Question about Roxio Easy Media Creator 7
I can not find the cover for key code - Roxio Easy Media Creator 7
  • Anonymous Aug 15, 2008
    lost key code for software
  • kempstera Oct 08, 2008
    i have lost my key code ?
    Novelist:
  • 233 Answers
Forget it... get the Roxio 10 instead.
http://www.roxio.com/enu/products/creator/suite/purchase.html?rtrack=C10newHP $80
Your Roxio 7 is so out of date.
Posted on Aug 02, 2008
How to program bottle deposit on xe-a507
PartsandTheirFunctions Printer cover Operator display Keyboard Drawer Check slot Drawer lock SD card slot (Refer to the "SD CARD Mode" section.) Printer The printer is a thermal printer, and therefore it does not require any type of ink ribbon or cartridge. The average life of the printer is approximately 6 million lines. When removing the printer cover, lift up its rear. When installing the printer cover, hook it on the pawls on the cabinet and shut it. CAUTION:Thepapercutterismountedontheprintercover.Becarefulnottocutyourself. Keyboard ? Keyboardlayout ? Functionkeylist { Receipt paper feed key PLU/sub-department/UPC key } Journal paper feed key Department code entry key Function menu key Department shift key a Auto key CLK# Clerk code entry key w Tax1 shift key Department 1-40 key 0 Percent 1 key FI Cursor (up/down arrow) key - Discount key m Mode key t Void key Escape/Cancel key H Help key X Charge 1 key f Refund key R Receipt print key @ Multiplication key Y Charge 2 key P Decimal point key u PLU/UPC inquiry key l Clear key x Check key 0 9 : Numeric key ; Non-add code/Time display/Subtotal key A Cash/Amount tender/No sale key Displays ? Operatordisplay •Screenexample1(REGmode) Salesinformationarea: When a transaction information occupies more than 2 lines, you can scroll to the direction by using the F I keys. Sales information you have just entered such as items and prices will appear between 1st line and 2nd line. Total is always appear at 3rd line. NumericEntryArea: Statusarea: Mode name Status information Clerk code Receipt ON/OFF status indicator (R) : Appears when the receipt ON-OFF function signs OFF. Sentinel mark (X) : Appears when the cash in drawer exceeds a programmed sentinel amount. The sentinel check is performed for the total cash in drawer.
Sep 28, 2016 | Sharp ELECTRONICS CORP. Xe a203 cash...
F1 Flash on dashboard
put it in dealer mode... with key off, take off seat, find the white plug with a cover on it. take off the cover and using a paperclip jump the white and black wire in the slots, theyre at the top of the plug. turn the key on and turn the red ignition switch on. It will now display what the code is. just google the code that it displays
Oct 02, 2013 | 2000 Suzuki GSX-R 750
Errore code sc 541
Your problem is in the fusing unit.Check the thermistors and thermofuses.Reset the code :
Interrupt(yellow)key - 1 0 7 -press and hold STOP/CLEAR key more 4 seconds,enter in SP mode,open the front cover,turn OFF the main switch,wait 1 minutes,close the front cover,turn ON the copier.
Feb 02, 2013 | Gestetner DSc338 Copier
ERROR 37.0 DUCATI
Immobilizer and transponder
The Immobilizer allows the vehicle to be started only if the rider uses the special ignition key which sends the identification code to a decoder fitted into the instrument panel. The emitting - receiving system is made of a "TRANSPONDER" fitted into the ignition key heads and an antenna close to the ignition lock.
Transponder keys
The two keys contain the secret master code for programming the immobilizer system and allowing engine start is stored into this key;
Transponder is included into the key head and consists of a power supply circuit, a ROM (Read-Only Memory) and a transmission circuit. The Transponder is power supplied through the magnetic field generated by the antenna which is enabled as soon as the instrument panel is switched on. As it is very compact and needs no outer power supply through a battery, it is directly fitted into the key head.
Warning
Circuits into the key head are not shockproof.
Immobilizer antenna
The antenna consists of a plastic-coated copper coil connected to wires ending up with a connector.
The antenna (A) is fitted onto the ignition lock into its specially designed seat.
Operating principle of the immobilizer
When the ignition key is positioned to ON, the decoder into the instrument panel energises the antenna, which generates an electromagnetic field power-supplying the key transponder. The Transponder sends the code stored into its ROM, which is received by the antenna and sent to the decoder. Here the secret code is matched with a second code. If this comparison proves successful, engine starting is enabled.
Immobilizer warning lights and indications
When the ignition key is turned to OFF, the immobilizer inhibits engine operation. When the ignition key is turned back to ON to start the engine, the following happens:
1) if the code is recognised, the immobilizer enables engine starting. Press the START button (2), to start the engine;
2) if the diagnostic light (8) comes on and the page with the message "Error IMMO" is displayed when you press button (1) in position B "t", it means that the code was not recognised. When this is the case, turn the ignition key back to OFF and then to ON again. If the engine still does not start, try with the other black key. If the other key does not work out either, contact the DUCATI Service network.
Caution
When programming the immobilizer as described below, use only the required key and keep the other keys away otherwise they might interfere.
Removing the immobilizer
Turn the ignition switch to OFF.
Disconnect Immobilizer antenna connector (21).
Note
Reference (21) is the same that is indicated in the diagrams under "Arrangement of wiring on frame", Sect. P 1.
Remove the immobilizer antenna wire ties.
Loosen screws (1) securing Immobilizer antenna protection to ignition switch.
Remove the cover (2) and the Immobilizer antenna (3) clear of the key-operated switch.
Refitting the immobilizer
Apply a drop of Loctite inside cover (2).
Locate antenna (3) to cover (2), and secure it in place with the two pegs (A) of the cover.
Fit the cover on the key-operated switch, easing the antenna wire downwards.
Tighten the cover starting screws (1) in their thread.
Tighten the screws to the specified torque (Sect. C 3, Frame torque settings).
__________________
Jan 22, 2013 | 2003 Ducati 999
Stuck in the C6400 Error and cannot get out of it, nor print anything. My printer is a KYOCERA KM-1820. Any assistance would be appreciated.
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note: Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset.
Mar 31, 2011 | Kyocera Copystar CS-1820 Black and White...
Is it possible to repair/replace cover of key inlet on drivers side door of nissan exalta 2000. without this small cover it allows water to go in that makes key mechanism stuck. thanks
yes it is , go to a bodyshop or dealer. make sure that the new key cylinder is coded to work with your key, they will have to send your key and new cylinder to locksmith for re-coding of cylinder.
Jan 15, 2011 | 2000 Nissan Sentra
Where is the key product number located on my pc
If you have an original Operating System installation CD, you will find the product key on the cover of the CD case. it is a 25 character code.
Dec 26, 2009 | Computers & Internet
Lost ignition key to my truck.Any way to get a new key?
Check your owner's manual. Many dealers will write the key code inside the back cover as an example for just such a situation. Get the key code and any locksmith should be able to make a new key.
If it's not in the owner's manual, try contacting the dealership that originally sold the truck and they may have the code in their file for the truck.
Oct 11, 2009 | 1985 Dodge Ram 3500
Set key code
on the 3240 you will need to have a jumper installed to remove the key counter. this is a hard setting not a softsetting. you need to remove th inside front right cover. under the cover is a 4 pin clear connector. you need to reinstall the jumper to tell the machine no keycounter is installed. the jumper should be under the cover
Sep 25, 2009 | Gestetner Copier
I bought replacement wire wheel cover for a
yes there should be a code in glove box for locks & key get it go back to dealer get one new lock
Aug 25, 2009 | 1992 Buick Roadmaster
Roxio Easy Media Creator 7 Logo
96 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
