Hotpoint WT741 is full with washing and water and showing a red F05 light. The washing machine door is locked and will not open for me to let the water out. What do I do? Many thanks
    Brigadier General:
  • 6,277 Answers
'F05' means 'blocked (drain) pump' (or more likely blocked filter!)
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 16, 2011
I have a hotpoint ultima wt741 , 4yrs old , washine machine does not show that the door is closed , the red closed light does not now come on and machine will not start. l have removed top of machine and...
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 03, 2011 | Washing Machines
Hotpoint ultima washing machine showing fault code f-05 and door will not open.
Error code F05 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Make sure there is no water in drum before you start.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt741 1400 spin-f-05 flashing on display board not empting or finishing wash?
Error code F05 means pressure switch jammed on full
Remove lower rear cover of washer.
Remove large black hose on bottom of tub.
Remove hose onto pump, and check for blockage or obstrucrtion here as well.
This should solve the problem.
PLease rate my solution.
Thankyou.
Jan 17, 2010 | Washing Machines
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Locate and remove large black hose fastened to drum.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT741 Front Load- unable to open door.
hi julie,
is there an error message on your display?
can you provide me with the complete model #?
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
Hotpoint ultima wt741
Hi.
F05 meqans that pressure switch is jammed.
You will neeed to call an engineer.
Jun 12, 2008 | Hotpoint WMA35 Front Load Washer
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Washing Machines Logo
148 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
