Question about Cell Phones
It does not play fm radio it says that signaliing is too weak
  • 83 Answers
Reset yours mobile phone from mobile setting or change yours FM anteena
Posted on Mar 16, 2011
Radio trouble shooting
It seem like the stereo for the radio is failing, either because of a weak radio signal or defective aerial
Jul 30, 2014 | Mercedes-Benz 1992 Mercedes 500SL Radio /...
I got a 91 chevy pick up with a cilfford, the radio works but hardly any sound comes out of speakers. I got a new radio and its the same. All speakers play buy sound is very low. I was told it was do to...
posted 6 times.
run new wires from new radio to speakers
or bench test your radio (easy) with your speakers.
if still low the speakers are bad or just dirt cheap , car speakers.
try new speakers, if weak now the wires are bad, try new wires
id still weak the radio is bad. (or just a cheap radio)
and define weak, to me most radios are way too load.
but to others, all are weak until 1000watt amp is added.
weak is a relative term. as is hardly any.
do not quote persons guessing, its just a wild guess. they can see car either, do the tests your self and find TRUTH.
to bench test, (modern way)
1: 12vdc 1amp power pack, or battery 12v. and ground.
2: connect up USB mem,. with some mp3s. on stick.
3: connect one good speaker (KNOWN GOOD)
to one of 4 speaker lines. (2 wires)
4: push play, does it sound good, yes, move to next speaker port.
ok , the radio is good. so
try it in the car, is it now low volumn
yes, then move that test speaker to the car speaker that is low.
still low, yes, then the wiring is bad.
easy huh?,,, takes only , a test speaker.
if no usb use, cassette, if no that , use CDDA disk( store bought real)
if none of that us the radio to test. connect a test antenna.
tune in Am or fm. bam.
May 06, 2014 | Cars & Trucks
How do you auto preset radio stations?
Hello
[1] Press RADIO BAND.AUTO PRESET until the band you want appears on the display [direct power ON]. Each time you press the button the indication changes as follows. "FM" => "AM"
[2] Hold down TUNE+ or --ve until the frequency digits begin to change in the display.
The player automatically scans the radio frequencies and stops when it finda a clear station. If you can't tune in a station, press the button repeatedly to change the frequency step by step.
If FM band is noisy, press the MODE repeteadly until "MONO" appears in the display and the radio will play it monatural. If FM radio signal at your area is very weak, this type of noise may occur. OK.
Sep 28, 2011 | Sony CFD-S350 Radio/Cassette/CD Boombox
IBOUGHT MY PHILIPS SAA7130 TV TURNER/FM RADIO THE MANUAL STATES THAT I MUST INSERT THE CD KEY FOR THE FIRST TIME WHEN ISTALING BUT I DIDNOT SEE THE OPTION WHEN INSTALLED MY CARD AND IT SAYS FM RADIO...
BOUGHT MY PHILIPS SAA7130 TV TURNER/FM RADIO THE MANUAL STATES THAT I MUST INSERT THE CD KEY FOR THE FIRST TIME WHEN ISTALING BUT I DIDNOT SEE THE OPTION WHEN INSTALLED MY CARD AND IT SAYS FM RADIO OPTIONAL BUT NOTHING IS PLAYING FROM RADIO
Mar 04, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
2008 s40, i have no am signal but FM plays and CD no problem
There is a possibility that the radio is set to receive ONLY very high quality, strong signals. Maybe you are just getting the strong FM signals, and not the weak ones, and that all your AM stations are weak. When set on this mode, you dont hear the white noise of weak stations, the radio automatically blocks them out.
Dec 04, 2009 | Car Audio & Video
The CD player on my Sony Dream Machine FM/AM CD clock radio will not play. I have left the CD compartment open per the troubleshooting instructions in the manual, to remove moisture but to no avail. When I...
The laser has gone weak. If you feel confident taking it apart, unplug it and look for a small potentiometer on the CD reading pickup. Turn it to the right to about 700 ohms, it should start reading again. If you don't have a multimeter to measure it then get one, a basic $10 meter will do fine.
Jun 26, 2009 | Sony Dual-Alarm AM/FM Clock Radio with...
No radio reception in office.
most portables have a very weak FM receiver, and a building interior tends to block a good deal of signals. your best bet is an old fashioned unit with a large retractable antenna.
Jun 12, 2009 | RCA RP7887 High-Performance Super Radio
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Cell Phones Logo
19 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
