When i try booting i get the message, "could not locate HDD, please try reseating the drive and restart you computer". please help.
  • 120 Answers
Your hard drive is dismounted. Try reconnecting your hard drive. Two basic reasons why it cannot detect the drive: 1. The drive doesn't get any power from the board. So make sure the power cable is connected tightly 2. The data cable is not attached correctly.
else
Your HDD is busted.
cheers
Posted on Mar 16, 2011
HP pavilion a1130n won't boot. It has power, when I turn it on everything lights up the disk drives open and close the HDD vibrates slightly and the fans are spinning but I get nothing. Tried new monitor...
you need a new motherboard chances are it's not your processor. Your motherboardif you like to computer you need to purchase the exact same motherboard
Nov 06, 2014 | Computers & Internet
Get message internal hard disk drive not
This may mean that your computer is trying to boot from a non-bootable drive. Try hitting f12 when you restart the computer and select which drive would have your OS on it. You want to change the boot sequence to diskette drive as your 1st choice. The order should be Diskette Drive, Internal HDD, USB storage Device, CD/DVD drive.
Apr 08, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
When i boot up my laptop i am getting the error message, "operating system not found." Can you please give me advice on what to do to fix my laptop? Toshiba laptop and im scared i may lose the things
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 30, 2012 | Toshiba Computers & Internet
Hello. Completely out of the blue, when I turned my laptop on it immediately went to a black screen that said "A disk read error occurred press Ctrl+Alt+Del to restart." But when I do it takes me...
When your system boots it looks for a startup file which is located on your hard drive to load your operating system. If your system doesn't find your hard drive it would post a disk read error message.
To be sure your HDD is detected by your system, you can go to your BIOS setting by pressing DEL or F1 or F2 or F12 it depends on your BIOS maker then try to see on your BIOS setting configuration if your HDD drive is detected or not.
Sometimes and always happens that we forget a media disc on our optical drive and since the default first boot device is the optical drive the system looks for a startup file on it and post a disk read error. So check if you leave any disc on your optical drive and remove it.
It is very safe to configure your BIOS setting to set the HDD as the first boot device in case we leave something on our optical drive most of the time.
Hope this helps.
May 27, 2011 | Computers & Internet
Starting my laptop i get this message internal hard disk not found To resolve this issude . try to reseat the drive "which i did" no bootable devices stike f1 to retry boot , f2 for setup utility...
Hi ajmedina89,
If your system wont boot up and has a no "bootable devices" message, is often caused by a defective harddrive. I recommend to try a different HDD before replacing your system HDD to isolate the issue.
Hope it helps.
Thank you for using FixYa.
Apr 25, 2011 | Dell Inspiron 1545 Notebook
My sony vaio pcg-551l won't go past "no operating system"
If this is the first time your trying to start up this computer try to restart it. Sometimes brand new laptops can fail to find the operating system on first startup. If this isn't the case it sounds like your Hard Drive is either disconnected or has had a critical failure.
Mar 15, 2011 | Computers & Internet
The problem of my hp pavilion dv5 is this, i want my laptop to be back on its original state so i tried system restore. i have my recovery discs aside from the built-in recovery partition. i inserted the...
You have formatted the hard drive (containing Boot Manager) using recovery disk 1.
That's why the error message.
Just insert disk 1 again.
Shut down the computer (press & hold the power button for a minute).
Restart.
Follow the instructions that come up.
If it doesn't help, reseat the hard drive. (open the back cover, take out hard drive, reconnect it)
Also you may go to BIOS (tap F1 while booting) and set the cd-drive as the first boot device.
Hope it helps.
Nov 06, 2010 | HP Pavilion dv5-1000us Notebook PC
Cant detect my western digital hard drive help! philippnes!
Shut down the computer.Disconnect the ide cable from hdd .Just connect using primary hdd and boot the computer. Shut down the computer. Connect the secondary hdd both IDE and power cable. Restart the system and go to bios . Check if the both hdd are detected in bios. If detected boot to desktop. If not detected reset bios settings to default.Restart computer and check. IF still not detected shutdown computer.Disconnected secondary hdd and primary hdd,connected secondary hdd to primary ide connecter and check in bios. If still not detected try connecting secondard hdd on different computer and check.
Aug 17, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
