Question about HP Photosmart 2610 All-In-One InkJet Printer
HOW DO I CLEAN THE GLASS ON MY HP 2610 PRINTER?
  • HP Master
  • 3,247 Answers
Use an isopropyle alcohol based cleaner and a clean white cloth.
This is the same fluid that you would use to clean the DVDs.
Posted on Mar 16, 2011
HP Photosmart 2610 all-in-one printer. I've replaced my color and black carts. with refilled ones. My color ink drained all over the bottom of the inside of the printer. I am no longer going to be...
You can use a degreasing spray or methyl alcohol to clean up the residual ink. Use a brush to clean and wipe and BLOW using a hair dryer to fully dry up the residue.
Make sure that there is no dirt at the terminals, clean and set with original cartridges from HP.
Now if there is errors then you must disconnect printer, uninstall then install the driver, connect printer when prompted and print a test page.
Sep 05, 2011 | HP Photosmart 2610 All-In-One InkJet...
Hp 2610 paper jams on print command. Paper pulls sideways.
find the paper feed rollers and clean them. they get slick and one side will catch quicker and pull the paper side ways.
Aug 12, 2010 | HP Photosmart 2610 All-In-One InkJet...
Copying is extremely slow but printing speed is fine
press the menu button, and then the copy option, under that you will find copy speed , see if that resolve your issue
Aug 17, 2009 | HP Photosmart 2610 All-In-One InkJet...
Hp 2610 will not print black even with new cartridge. HELP
Try cleaning the gold contacts on cart first, with distilled water. Let dry and try again.
If not, try this one
1.Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Inkypete
May 24, 2009 | HP Photosmart 2610 All-In-One InkJet...
Cleaning the scanning glass
Hard to get a smudge inside but basically you take it apart and clean the inside of the glass
Aug 31, 2008 | HP Photosmart 2610 All-In-One InkJet...
Hp photosmart 2610 all in one
yes !! you can download the installation program for your printer thru the HP Website , heres the link :
click or copy paste :
http://www.hp.com/support , enter your printer model and your set , hope this helps , please rate & thanks AJ
May 21, 2008 | HP Photosmart 2610 All-In-One InkJet...
Scanner problem
HI,
In case u have installed the software on your computer , u can look for hp director on your pc ,
when u open p director > click settings > printer settings > printer settings > printer tool box > under that window > u will find service product tab , simpy click on that .
in case it does not help or u cannot find it .>
u can press set up on the printer > go to the tools option [ by pressing the down arrow key ] > press ok > go to clean print head , clean cartridge , allign printer > it will service the product .
u can reset the printer to its factory deafults as well
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Note - you can also try the Ok n cancel key combination in place of # and 6 .
But do not use the reset frequently.
May 13, 2008 | HP Photosmart 2610 All-In-One InkJet...
Clouds on everything I print.
Found it! Here is the step-by-step for removing the glass... I think I will take the instructions and printer to a shop to have it done!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00553775&lc=en&cc=us&dlc=en&product=421999
Dec 06, 2007 | HP Photosmart 2610 All-In-One InkJet...
Haze on INSIDE of HP 2610 AIO scanner glass - how to remove glass?
with the 2610, on the right side remove gently the coverplate and then slide the under panel down. There are four places it attaches to the printer case one at each corner approximately. you can try to do what I did and use a greenie flathead screwdriver to pry it free, or do the not so obvious but much easier and kinder to the machine version of pushing it down to get the L shaped plastic pieces to release from the upside down L underneath. then there are three size T10 hex or star shaped screwdriver screws to release three of the four sides. I never could get the front silver fitted piece off, but was able to remove the glass. DO NOT CLEAN WITH WINDEX...IT LEAVES RESIDUE. USE VINEGAR. ALSO, USE WHITE GLOVES AS any dust you get on it cleaning it will leave small fibers on both sides. I used a special glass cleaning rag and then gently replaced it. note which side the black strip goes when you remove the glass!
Oct 27, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
47 people viewed this question
Seeker5211
Seeker5211
