Question about Kitchen Ranges
Wolf Gourmet Range oven lighting delay
I bought a house with a Wolf Gourmet ?professional 6 burner range/convection oven. It has worked fine, but recently the oven can take up to 10 minutes to light and start heating up. It does eventually light on its own and the pilot light can be seen underneath. The range top works and light (by spark) normally.
  • 1 more comment
  • allenalt Aug 08, 2008
    I have the same problem. Any answers?
  • serotta Feb 26, 2009
    i have the same problem
  • Anonymous Mar 17, 2014
    oven pilot is way to high
UPDATE to Solution #1: I just went to the Wolf Appliance website and found that the recall is still active, at least for the 48" models. Here's the URL: http://www.wolfappliance.com/recall.aspx There are instructions, affected models and serial numbers, etc. You can also call the "Rework Hotline" at 866-643-6408 or send an email to range18.rework@wolfappliance.com
Posted on Sep 04, 2008
This sounds like a problem that was common at the time these ranges were sold -- it prompted a recall:
http://www.cpsc.gov/cpscpub/prerel/prhtml02/02022.html
Hopefully you can still get it fixed. BTW, these ranges were manufactured through 2000 by the Wolf Range Co., which only makes the commercial models now. Residential ranges are now marketed under the Wolf brand by Sub-Zero.
I bought from a private party a used Wolf range Challenger Model CHR-4-29-HB11, oven worked fine. First I was baking and heard stove making a phfttt, phftt, noise. Then took food out and noticed oven...
Pilot lights go out because the Thermocoupler is either bad or not getting hot enough. It will be a copper tube that should touch the pilot light flame. these are replaceable and usually any appliance repair supplier can get you one. Some units reuire changing out the entire gas control
Oct 17, 2013 | Wolf Range CHR-10-229-FT11 Kitchen Range
Wolf gourmet gas range/oven 36"--oven lights and
is this a duel fuel unit if so the the electric bake element is open
Sep 19, 2011 | Wolf Range KFS-0-27-SCB-36 Gas Kitchen...
Viking model vdsc4874gss small oven works fine large oven element on bottom only gets hot in cleaniong mode, fan comes on when dial is turned to convection but no heat power is on light works
One thing that you can check is make sure that you have 220 volts at the plug. Leave the unit unplugged and check continuity on the burners. You should have continuity on the burners.
Oct 18, 2010 | Viking 48" 6 Burner, Grill Professional...
I just got my (new to me) pre-1990 Wolf 36'' range connected (by a certified pro). 4 burners, 12'' fry top/charbroiler/cheesemelter thingie on left, 4 burners on right, 29'' oven - propane. It has not been...
the oven pilot has 2 setting first setting is for you to light small flame, should not be all yellow if it is it has a dirty orifice inside the pilot hood, you can remove this by disconnecting the pilot line from the hood and removing orifice for cleaning, just rub it with a cloth.once clean and replaced you light pilot and check it out. if its ok turn on oven and secondary pilot will ignite that why it got bigger!! this heats a flame sensor to allow 100% safty vavle to open to let gas into burner so yuo can cook.
Feb 02, 2010 | Wolf Range CHR-0-29-FT34 Gas Kitchen Range
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Have a Wolf Range Model A-6-9 half the burneres don't light.
I have the same model Wolf Range and need 2 of the Robertshaw SM4 spark modules for it. Robertshaw says they are discontnued. Where can I locate 2 spark modules?
Jul 10, 2009 | Wolf Range Kitchen Ranges
DCS 4 burner plus griddle Range..oven doesn't heat
This happened to my DCS when the Hot Wire Relay went out. It isn't an expensive part, but finding someone that knows what needs to be replaced, and then can replace it is hard. My oven also did the opposite and continued to heat without shutting off, and it was once again the hot wire relay.
Jan 11, 2009 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
Older 6 burner wolf commercial range ignition problem.
If it were the gas regulator, existing flames would go down as more burners are turned on.
There are set screws on the pilot fittings that come out of the manifold, you could try turning those Counter-clockwise to turn the pilots up. (Don't loosen them all the way, they will fall out!) If that doesn't work chances are the pilot stems will have to be replaced to get a higher pilot flame.
Mar 07, 2008 | Wolf Range CHR-10-229-FT11 Kitchen Range
Kenmore Elite Electric Convection Oven Not Working
Check the voltage at the wall Sounds like you have lost one 120 voltage side Red to white should read 110-120 black to white should read 110-120 red to black should red 220-240 check at range and at the wall hope this helps
Aug 25, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Kitchen Ranges Logo
1,396 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
