I am getting the error code "HC" since we replaced a hot water heater. What does it mean? How might I correct this? Whirlpool Cabrio
  • 3,740 Answers
There is most likely debris from the plumbing repair / install of the hot water heater that has migrated into the inlet screens of the washing machine. Turn off the water supply. Remove the water hoses from the water inlet valve and then use a thin bnladed kinfe to coax the inlet screens out of the inlet water valve body. Wash then under slow running water by gently rubbing your fingers over them until they are clean. Hod the screens up to a light source to make sure you have them totally clean. Reinstall the CLEANED screens and connect the water. This should correct the HC code.
If not there is one more series of steps to do:
- Water supply OFF
- Remove both hoses at water valve inlet
- Remove the inlet screens
- Reconnect BOTH hoses to the inlet water valve.
- Remove ONE hose from the Wall water supply and place it in a bucket TURN ON THE REMAINING HOSE connected to the wall.
- Start a WARM fill cycle and tap the water valve hose connections with the HANDLE of a hammer or the head of a very large screw driver while the unit is filling. (15 seconds)
- Stop fill cycle and turn off water to connected hose
- Reconnect removed hose to the wall connection.
- Reverse hose positons and place 2nd hose in the bucket. Thern ON the hose still connected to the wall.
- Start a WARM FILL cycle.
- Gently tap the water valve hose connections 15 seconds
- STOP Fill
- reinstall inlet screens and connect all hoses.
- test fill cycle and return to normal service
Thanks for choosing FixYa,
I am Kelly
Posted on Mar 16, 2011
Testimonial: "I appreciate the throughness of your response. It shows enough detail that I can 'picture' what you are saying even though. I will try this. Thanks"
What does code uL mean. this comes on in the drain spin cycle
Hi, a UL error code means a load not balanced. The washer is running a load-balance correction routine. Please allow the washer to continue. If the dial is flashing and the washer has stopped, redistribute the load, close the lid, and press START/PAUSE.
Aug 14, 2016 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
What does "HC" mean?
The HC code indicates that the computer thinks the cold water inlet is getting hot water. The hot water inlet has the cold water coming in. Take off the inlet hoses and double check your water lines. If needed, swap the connections. While you have the hoses off, clear the filters and check for leaks. Check the flow rate and replace the hoses if the water flow is restricted. (Anti-burst hoses can reduce the flow when they detect a leak.)
If the hot water supply is correctly connected to the hot water inlet, then the electronic control board is getting faulty information. Unplug the washer for several minutes. If the code repeats, then the valve may be faulty. Alternative causes of the problem are the hoses, the wiring or the control board.
I hope this helps.
Mar 16, 2016 | Whirlpool WTW6400SW Cabrio Washer
HC code shows up after washing cycle is over
HC flashes when the hot and cold inlet hoses are reversed.
Make sure inlet hoses are connected correctly.
http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Aug 25, 2014 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
Im receiving the LF code what does this mean??
Check that the drain hose and water inlet hose are properly installed, and undo any kinks or clear any clogs if the display error reads "LF" indicating that the load is taking too long to fill, or "Ld" indicating that the washer is taking to long to drain. If the code reads "HC," the hot water hose is installed in the spot for the cold water hose and vice versa.
Also, check this information from Whirlpool DataBase: Display shows LF
Hope helps (remember to rate and comment this answer).
Sep 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My cabrio washer shows a code HC...what does this mean?
HC will flash when the hot and cold inlet hoses are reversed. Make sure your inlet hoses are connected correctly. That should correct the issue.
Jun 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 problem with cabrio wtw6300swo what part do I need to replace to correct this code?
The F1 error means the central electrical control unit, i.e. the onboard computer, has failed. This is a fatal error and means that the board has to be replaced. To remove it unscrew three screws at the rear to expose the control panel, then unplug one unit; plug in the new one. The price of the unit varies between $170 and $295.00 depending on where you buy it. (CODE # 083009 part # W10189966 CNTRL-ELEC). If you are not able to do this then get 2 or 3 a repair / service engineers to quote you for the job.
Oct 12, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
What does HC stand for?
According to the Whirlpool "Cabrio" washer installation and maintenance manual, (Cabrio is the Sears Oasis) the HC code will come up when.
“HC” (Cold and Hot hoses switched)
This code will appear at the end of the wash
cycle to indicate that the cold and hot water
inlet hoses are switched. If an error code
does not appear, but you are experiencing
poor washing performance, check to see
whether the inlet hoses are reversed. See
“Connect the Inlet Hoses.”
Sep 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Error code HC
I recently started getting this message as well. I found out that I accidentally switched the hot and cold water lines into the washer. After switching so hot goes to hot and cold goes to cold the 'hc' message has stopped.
Apr 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
209 people viewed this question
Top Washing Machines Experts
